大家好,
我现在正在使用zynq 706进行项目。有两种方法可以将Host与FPGA连接。 一个是SD卡,另一个是PCIe。 如果我选择SD卡,spartan或virtex的数据速度只有几百Kbps,但我找不到zynq板的数据速度。 我假设数据路径是从FPGA板到嵌入式微处理器,然后是嵌入式微处理器到FPGA,那么如果我想使用SD卡,有人能告诉我数据速度吗? 谢谢, 里 以上来自于谷歌翻译 以下为原文 Hi all, I am now doing projects with zynq 706. There are two ways to connect Host with FPGA. One is SD card and the other is PCIe. If I choose SD card, the data speed for spartan or virtex is only hundreds of Kbps, but I cannot find the data speed for zynq board. I assume the data path is from FPGA board to embedded microprocessor and then from embedded microprocessor to FPGA, so can someone tell me the data speed if I want to use the SD card? Thanks, li |
2个回答
- 检查SD时钟配置。
有关时钟的信息,请参阅UG585第25章。 请提供寄存器设置和完成的计算以验证SD时钟频率。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 - Check the SD clock configuration. See UG585 chapter 25 about Clocks. Please provide the register settings and the calculation done to verify the SD clock frequency.Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
对此没有直接的答案,因为它取决于很多因素。线程-https://forums.xilinx.com/t5/Embedded-Processor-System-Design/SD-card-performance-using-Zynq-SDIO-
和-Linux-what-data-rates / td-p / 323563为您提供了相关的见解。 -------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 There is no direct answer to this as it depends on lot of factors. The thread-https://forums.xilinx.com/t5/Embedded-Processor-System-Design/SD-card-performance-using-Zynq-SDIO-and-Linux-what-data-rates/td-p/323563 gives you insights on this.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2078 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1638浏览 0评论
GMT+8, 2024-4-24 06:49 , Processed in 0.971990 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
