扫一扫,分享给好友
嗨,
我试图使用Vivado 2015.2从源自Modelsim仿真的VCD获得功率估计。 但是,Vivado 2015.2只能获得SAIF文件。 我没有选择输入VCD文件进行功率估算。 我读了UG907,但是不同的版本给出了不同的描述:2012版本可以接受VCD,而更新的版本2014或2016表示它只接受SAIF文件。 有一些问题: 1.如果我想使用VCD文件,是否需要取消当前版本并安装较旧版本,如2012? 另外,如果我想更新2015.2到2016.4的版本,有没有一种方法我可以使用而不会取消当前版本,然后安装完整的2016版本? 2. Modelsim可以输出SAIF文件吗? 否则,我如何将Modelsim结果转换为功率估算? 3.如何估算VCD和SAIF不同时段的功率(例如10-20 ns)? 最好的祝愿, Killua 以上来自于谷歌翻译 以下为原文 Hi, I am attempting to use Vivado 2015.2 to obtain power estimation from VCD derived from Modelsim simulation. However, the Vivado 2015.2 can only accpet SAIF file. There is no option for me to input a VCD file for power estimation. I read the UG907, but different version gives different discription: 2012 version can accept VCD while later version 2014 or 2016 state that it only accept SAIF file. There are some questions: 1. If I want to use VCD file, is it necessary to unistall the current version and install an older version such as 2012? Also, if I want to update the version from 2015.2 to 2016.4, is there a method I can use without unistalling the current version and then installing the full 2016 version? 2. Is it possible for Modelsim to output a SAIF file? Otherwise, how can I convert Modelsim result into power estimation? 3. How can I estimate the power in different time periods for VCD and SAIF (e.g. 10-20 ns)? Best wishes, Killua |
2个回答
检查此ARs http://www.xilinx.com/support/answers/55089.html
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check this ARs http://www.xilinx.com/support/answers/55089.htmlThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@balkris,感谢您提供的信息。
但似乎VCD在Vivado 2014这样的高级版本中仍然无效。我想用VCD代替SAIF的是我能够将文件剪切成几段以方便模拟不同的时间段。 对于我的情况,你有什么建议吗? 以上来自于谷歌翻译 以下为原文 @balkris, thanks for the information. But it seems that VCD is still invalid in higher version such as Vivado 2014. The thing I want to use VCD instead of SAIF is that I am able to cut the file into several segments for the convenience of simulating different time period. For my situation, do you have any suggestions? |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2589 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2062 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2163浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-28 22:11 , Processed in 0.927053 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
