嗨,ZYNQ APSOC中是否存在类似CCLK的等效引脚,因为它存在于其他7个FPGA系列中。
谢谢& 问候, 阿努拉格 以上来自于谷歌翻译 以下为原文 Hi, is there any equivalent pin like CCLK in ZYNQ APSOC as it is present in other 7 FPGA series. Thanks & Regards, Anurag |
4个回答
@ anurag18No,Zynq不会有任何CCLK引脚,因为Zynq SOC配置机制与FPGA不同。
-Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @anurag18 No, there will not be any CCLK pin for Zynq as Zynq SOC configuration mechanism is different than the FPGAs. -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
谢谢Pratham,
那么请你建议配置zynq soc PL的其他方法。 问候。 阿努拉格 以上来自于谷歌翻译 以下为原文 Thanks Pratham, so can you please suggest the other methods to configure the PL of zynq soc. Regards. Anurag |
@ anurag18请参阅Zynq的引导和配置。
http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 @anurag18 Refer to Boot and configuration of the Zynq. http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
谢谢pratham,
我们正在使用我们的zynq cypress FX3s。 首先,我们使用JTAG使用硬件管理器配置zynq,我们可以对其进行配置。 然后当我们转向FX时,将图像文件引导到FX3,那时引导加载程序设备在pc硬件管理器中不可见。 如果我们先做FX3,那么我们就无法配置zynq。 那么请您指导我们如何配置FX3和zynq。 谢谢。 Anurag Ingle 以上来自于谷歌翻译 以下为原文 Thanks pratham, we are using cypress FX3s with our zynq. First , we are configuring zynq using JTAG using hardware manager , we are able to configure it. Then when we are moving to FXs, to boot the image file into FX3, at that time the bootloader device is not visible in pc hardware manager. And if we do FX3 first then we are not able to configure zynq. So could you please guide us how to can configure both FX3 and zynq. Thanks. Anurag Ingle |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-20 11:31 , Processed in 1.180007 second(s), Total 69, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
