我发现即使在1.4安培下,L6474的运行也非常热。它在一块不错的PCB上,有20块板,背面有一个小散热片(1英寸×1英寸),在不到2分钟的时间里它会上升到110℃。它也是power36包。我的PS电压是42伏。
我的电荷泵电压约为8伏。无论我是否使用3.3伏稳压器在外部为逻辑供电都无关紧要。 我已经花了很多精力来设计这个小型控制器,但按照这个速度,我可能不得不转向更好的芯片。 我过去使用的是L6207,在2安培/相位和45伏电压下非常酷。这是更大的24 powerDip 为什么ST会使这个芯片变得如此之小并且具有高导通电阻的mosfet?更大的芯片会更好。我甚至无法想象使用带有小型TSSOP封装的L6474H。 如果ST采用更大的引脚间距制造这种芯片,我相信客户。会更开心额定电压为3安培和45伏特的电机芯片非常大。为什么芯片必须是微观的? 以上来自于谷歌翻译 以下为原文 I'm finding that the L6474 runs terribly hot even at 1.4 amps . Its on a decent PCB with 20 plates thru tholes a small heatsink (1'' x 1'') on the back and it will rise to 110 C in less than 2 minutes . It is the power36 package too. My PS voltage is 42 volts. My charge pump voltage is about 8 volts. And it doesn't matter much whether i power the logic externally with a 3.3 volt regulator or not. I've put a lot of effort into designing this small controller , but at this rate i may have to move to a better chip. I've used the L6207 in the past and it ran very cool at 2amps/phase and 45 volts. It was the larger 24 powerDip Why would ST make this chip so small and have mosfets with a high on resistance ? A larger chip would have been alot better. I can't even imagine using the L6474H with the tiny TSSOP package. If ST made this chip in a much larger package with wider pin spacing , i'm sure customers. would be happier. The motor a chip rated at 3 amps and 45 volts is quite big. Why does the chip have to be microscopic ? |
3个回答
你好,
你能分享L6474配置吗? L6474应该比L6207更好,因为RdsON越低。在这种情况下,封装不重要(如果电路板布局相同)。 恩里科 以上来自于谷歌翻译 以下为原文 Hello, Can you share the L6474 configuration? the L6474 should be better than the L6207 cause the lower RdsON. The package in this case in unimportant (if the board layout is the same). Enrico |
>>您可以共享L6474配置吗?
我没有改变配置。它默认上电。我编程的全部是当前和步进分辨率。 >>在这种情况下,包不重要(如果电路板布局相同)。 L6474电路板布局不同,因为L6207使用更大的功率24电流,而L6207在通电时不需要处理器对其进行编程,因此电路板完全不同。 L6207在相同类型的散热片下几乎冷却。 以上来自于谷歌翻译 以下为原文 >>Can you share the L6474 configuration? I haven't change the configuration. Its the default power up. All I program is the current and the step resolution. >>The package in this case in unimportant (if the board layout is the same). The L6474 board layout is different because the L6207 used a larger power 24 dip and the L6207 didn't need a processor to program it on powerup, so the boards are totaly different . The L6207 ran almost cold with the same type of heatsinking. |
你好,
默认配置可能会导致高开关频率,从而导致强大的功耗。 请尝试以下配置: TON_MIN = 4我们 TOFF_MIN = 21我们 TOFF_FAST = 10我们 FAST_STEP = 16我们 TSW = 44 us 问候 恩里科 以上来自于谷歌翻译 以下为原文 Hello, the default configuration could cause high switching frequency and as a consequence strong dissipation. Try the following configuration: TON_MIN = 4 us TOFF_MIN = 21 us TOFF_FAST = 10 us FAST_STEP = 16 us TSW = 44 us regards Enrico |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1445 浏览 1 评论
2113 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2822 浏览 6 评论
5238 浏览 21 评论
361浏览 4评论
535浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
278浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
603浏览 3评论
509浏览 3评论
GMT+8, 2024-4-24 01:36 , Processed in 0.834727 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
