扫一扫,分享给好友
有人知道WebSyServyNvMMMPFS与WebNETHyServ.NVMMMPFS演示应用程序之间的区别是什么吗?查看WebSyNET应用程序的主要帮助文件,它们显示了设置WOLFSSL模块,所以我假设演示应用程序已经为Web界面提供了加密连接。除了此之外,还有什么不同吗?任何输入是赞赏!谢谢,John Vickers
以上来自于百度翻译 以下为原文 Does anyone know what the difference between the web_server_nvm_mpfs vs webnet__server_nvm_mpfs demo apps are? Looking in the main help file for the web_net application, they show setting up the WOLFSSL module, so I assume that demo application has encrypted connections for the web interface. Is there anything different other than that? Any input is appreciated! Thanks, John Vickers |
4个回答
这里有一些细节:HTTP://www. McCHIP.COM/FUMMS/M93627.ASPX.请让我们知道是否需要更多信息。
以上来自于百度翻译 以下为原文 There are some details here: http://www.microchip.com/forums/m936270.aspx Please let us know if more info needed. |
因此,在阅读并最终获得演示应用程序运行后,这些似乎是主要的区别(让我知道如果我缺少什么):1)Web版本是旧HTTP服务器,在和谐& lt;2。这是一个稳定的Web服务器,但没有充分的基础来容易地集成像WolfSSL这样的东西来进行加密的网页连接。2)WebSnet版本是微芯片开发的新的HTTP服务器样式,它增加了动态变量替换和服务器端包括。它还具有更好的处理加密的结构,因为它在处理客户端时具有静态套接字,极大地减少了做HTTPS页面的开销。这是它的症结所在吗?看起来像启动一个新项目,人们应该学习服务器的新WebNETWeb版本。谢谢,John Vickers
以上来自于百度翻译 以下为原文 So after reading that and finally getting the demo app to run, it seems like these are the main differences (let me know if I am missing something): 1) The web version is the old HTTP server that was in Harmony <2.0. This is a stable web server, but didn't have the full underpinning to easily integrate things like WolfSSL to have encrypted web page connections. 2) The web_net version is the new style of HTTP server that Microchip has developed which adds dynamic variable substitution and server side includes. It also has better structure for dealing with encryption because it has static sockets when dealing with a client which dramatically reduces the overhead of doing HTTPS pages. Is that the crux of it? It looks like for starting a new project people should probably learn the new web_net version of the server. Thanks, John Vickers |
此外,如果这有助于其他人外出,我之所以难以看到样本网页是因为我试图直接访问我的董事会的IP地址。如果你把地址栏放在“x.x.x.x”中,它会自动路由到“http://x.x.x.x”。因为这不是加密的地址,演示应用程序会拒绝连接。相反,请确保您访问“http://x.x.x.x”。访问它的另一种方法是在地址栏中键入“MCHPBOARDIGE”。请注意,一些路由器或计算机将不允许这种风格的地址查找。如果它不工作,请使用Microchip TCPIP发现工具在您的和声目录中找到您的板的IP地址,并用HTTPS地址直接连接到IP。John Vickers
以上来自于百度翻译 以下为原文 Also, in case this helps someone else out, the reason I was having trouble seeing the sample web pages is because I was trying to access the IP address of my board directly. If you put in your address bar "x.x.x.x" it will automatically route to "http://x.x.x.x". Because this is not the encrypted address, the demo application will reject the connection. Instead make sure you access "https://x.x.x.x". The other way to access it is to just type "mchpboard_e" into the address bar. Do be aware that some routers or computers will not allow this style of address lookup. If it doesn't work use the Microchip TCPIP Discoverer tool in your Harmony directory to find the IP address of your board and connect to the IP directly with the HTTPS address. John Vickers |
是的,我认为你列出了最重要的特征。新的设计应该使用HTTPNET。请让我们知道您希望在HTTPNET服务器中实现的任何新特性,我们将设法及时地添加/添加它们。
以上来自于百度翻译 以下为原文 Yes, I think that you've listed the most important features. New designs should use the http_net. Please let us know of any new features that you'd like to see implemented in the http_net server and we'll try to address/add them in a timely manner. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 13:15 , Processed in 1.366540 second(s), Total 76, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
