亲爱的各位,
我使用的芯片CY8C5668 AXI-060和PSoC 5开发包CY8CKIT-050。 我目前正在建设一个单一的项目2定时器。 但是,当我构建了附加的源代码时,我得到了一个错误,即中断处理程序是未定义的。 有人能告诉我吗? 谢谢 time3.Zip 2.2兆字节 以上来自于百度翻译 以下为原文 Dear all, I am using the chip CY8C5568AXI-060 and the PSoC 5 development kit CY8CKIT-050. I am currently building 2 timer in a single project. However, when I built the attached source code, I got an error that the interrupt handler is undefined. Can anyone please advise? Thanks
3个回答
的cy_isr关键词必须用来写你的interrupt_routines。您使用的是CysiISR1和CysISR2,这是不正确的。你有在两botht例程使用interrupt_handler中断。重命名它说interrupt_handler_1和interrupt_handler_2。
谢谢, SRIM 以上来自于百度翻译 以下为原文 The CY_ISR keyword must be used to write your interrupt_routines. You used CY_ISR_1 and CY_ISR_2 which is incorrect. You have used Interrupt_Handler in botht routines of the two interrupts. Rename it to say Interrupt_handler_1 and interrupt_handler_2. Thanks, srim |
你好,
我用自由来纠正和重新安排你项目中的一些错误。CysISR是宏,它的参数是中断处理程序的名称,所以您切换它们都会给您带来错误。 还有2条警告,其中一条是我的,来自评论。 第二个是关于在时钟/启用时违反设置时间的警告。首先,这应该是致命的(有时是错误的)第二:目标不是时钟或使能,它是来自输入引脚的(同步)复位。我相应地改变了你的一个频道,这样你可以更好地比较它们。可能需要用FF延长/缩短复位信号以获得更好的结果。 鲍勃 定时器11Zip 437.3 K 以上来自于百度翻译 以下为原文 Hi, I took the freedom to correct and re-arrange some errors / lines in your project. The CY_ISR is a macro and its parameter is the name of the interrupt-handler, so you switched them both giving you the errors. There are still 2 warnings, one of them is mine, coming from a comment. The second is a warning about violating setup-times on clock/enable. First: this should be considerd to be fatal (misfunction sometimes) Second: the target is not clock or enable, it is your (synchronus) reset coming from an input - pin. I changed one of your channels accordingly, so that you may compare them both better. It might turn out that you need to lengthen/shorten your reset-signal with a FF to get better results. Bob
亲爱的各位,
谢谢你的回复。 嗨,Bob Marlowe先生, 我无法完全理解你的回复。 “第二个警告是关于在时钟/启用时违反设置时间的警告。第一:这beconsiderd是致命的(失效有时)二:目标没有时钟或使,这是你的(同步)复位输入引脚来。我改变了你的一个渠道,因此,这样你可以比较他们更好。也许会发现你需要延长/缩短与FF得到更好的结果你的复位信号。” 你的意思是复位输入引脚必须同步时钟吗?如果是,为什么重置必须与时钟同步?这是因为如果不同步,复位不能工作? 对不起,这个问题,我刚开始一个月前在PSoC开发,希望能把它用在我的申请。 当做 以上来自于百度翻译 以下为原文 Dear all, Thanks for all the reply. Hi Mr Bob Marlowe, I cannot quite understand your reply below. "The second is a warning about violating setup-times on clock/enable. First: this should be considerd to be fatal (misfunction sometimes) Second: the target is not clock or enable, it is your (synchronus) reset coming from an input - pin. I changed one of your channels accordingly, so that you may compare them both better. It might turn out that you need to lengthen/shorten your reset-signal with a FF to get better results." Do you mean that the reset input pin must be synchronise to the clock? If yes, why must the reset be synchronise to the clock? Is it because if it is not synchronise, the reset will not be able to work? Sorry for the question, as I have just started on PSoC development about 1 month ago and is hoping to use it in my application. Regards |
只有小组成员才能发言,加入小组>>
713个成员聚集在这个小组
加入小组1888 浏览 1 评论
1639 浏览 1 评论
3393 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1556 浏览 6 评论
1371 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
170浏览 2评论
170浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
304浏览 2评论
325浏览 1评论
45浏览 1评论
GMT+8, 2024-3-29 15:00 , Processed in 0.773715 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
