我有一个设计,我使用2个时钟域,用MMCM创建(我需要一个级联来获得我需要的确切频率)。
我已将'处理器系统复位'模块连接到clk_out1和clk_out2时钟输出,因此每个域都会正确复位。 我(想)我可以在这里使用单个复位IP,并连接2个时钟中最慢的时钟,但如果没有我的硬件(正在开发中),第二个clk_out2端口模拟一个异步板时钟,稍后将进入我的设备。 clk_ou1是100MHz,我把clk_out2设置为13MHz,或多或少地模拟异步时钟输入。 2个问题: 1)我应该使用处理器系统复位的dcm_locked输入并将其连接到时钟向导的锁定引脚(此处未启用),还是可选的? 2)我可以以某种方式“重置/同步”重置IP,所以他们都等到两个时钟的重置完成? **如果答案是有帮助的话,那就是kudo。 如果您的问题得到解答,请接受解决方案 以上来自于谷歌翻译 以下为原文 I have a design in which I use 2 clock domains, created with MMCM's (I needed a cascade to get me the exact frequency that I needed). I've connected a 'Processor System Reset' block to both clk_out1 and clk_out2 clock outputs, so each domain gets it's proper reset. I (think) I could use a single reset IP here, and connect the slowest of the 2 clocks, but in absence of my hardware (under development), this second clk_out2 port simulates an asynchronous board clock that later will enter my device. clk_ou1 is 100MHz, and I put clk_out2 to 13MHz, to more or less simulate an async clock input. 2 questions : 1) should I use the dcm_locked input of the Processor System Reset and connect it to the lock pin of the clocking wizard (not enabled here), or is this optional? 2) can I somehow 'connect/synchronize' the reset IP's to each other, so they both wait until the reset completes for both clocks? ** kudo if the answer was helpfull. Accept as solution if your question is answered ** |
1个回答
1)是的,使用clk_wiz_1中的dcm_locked(最后一个DCM锁定)到两个PSR。
2)由于两个PSR都连接到相同的dcm_locked,因此它们将尽可能不同步。 由于(可能)不同的时钟频率,PSR的输出将被分开。 肯 以上来自于谷歌翻译 以下为原文 1) Yes, use dcm_locked from clk_wiz_1 (last DCM to lock) to both PSRs. 2) Since both PSRs would be connected to the same dcm_locked, they will be as in-sync as possible. The outputs of the PSRs will be separated due to the (presumably) different clock frequencies. ken |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2589 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2062 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1502浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2163浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-28 19:31 , Processed in 0.938911 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
