扫一扫,分享给好友
今天,我的电脑上的柏树更新经理告诉我有一个更新的PSoC程序员。
我允许它做“更新”,但它所做的一切都是不安装我现有的PSoC程序员,留给我没有程序员和PSoC Creator也无法编程设备。 我从CyPress网站上直接下载了安装程序,但它只是在没有安装任何东西的情况下运行到完成。简单地说,它是“修复PSoC Creator”。 无论如何,我设法让它重新安装到Windows控制面板和删除剩余的PSoC程序员那里,然后重新运行安装程序,我已经从赛普拉斯网站下载。 然而,随着最新的PSoC程序员,我现在在“程序员”和“创建者2”中都得到了这个错误。错误读取: 错误:dg.M00 23:在编程设备时出错:PSoC程序员报告错误(100)失败!用户NVLS更新失败。此操作可在电压范围1.8~3.3 V内完成。 过去我一直把程序员设置为5.0V,完全没有问题,并且有数百个设备这样编程。这是新的要求还是某种bug?我的设备是PSOC5 CY8C5688 AXI-060。我的硬件设计有5.0V的所有VDDIO引脚,为什么我不能在5.0V编程设备? 以上来自于百度翻译 以下为原文 Today the Cypress Update Manager on my PC told me there was an update to PSoC Programmer. I allowed it to do the 'update' but instead all it did was un-install my existing PSoC Programmer which left me with no programmer and with PSoC Creator unable to program devices also. I maually downloaded the installer from the Cypress website - but it just ran to completion without actually installing anything. It briefly showed that it was "repairing PSoC Creator". Anyway, I managed to get it re-installed by going to the windows control panel and removing the remnants of PSoC Programmer there and then re-running the installer which I had downloaded from the cypress site. However, with the latest PSoC Programmer I am now getting this error in both 'Programmer' and 'Creator 2.0'. The error reads: Error: dbg.M0023: There was an error while programming the device: PSoC Programmer reported error (100 - FAILED! User NVLs update failed. This operation can be completed in voltage range 1.8 - 3.3 V only.) I have always had my programmer set to 5.0V in the past with no problems at all and have hundreds of devices programmed this way. Is this a new requirement or some kind of bug? My device is a PSoC5 CY8C5588AXI-060. My hardware design has all the VDDIO pins at 5.0V so why cannot I Program the device at 5.0V? |
5个回答
你好,
我试着在你的原创帖子提到的再生步骤;卸载和重新安装最新的程序可以在网络上(http://www.cypress.com/?摆脱= 38050 &;源=头)和我有3.14.0.1126 PSoC程序员编程与5V没有烦恼。 一种选择是改变硅并重试。 另外,你能更多的提供信息的程序设置,你用吗? 谢谢, SRIM 以上来自于百度翻译 以下为原文 Hi, I tried reproducing the steps as mentioned in your original post; uninstalling the programmer and reinstalling with the latest available on the web (http://www.cypress.com/?rID=38050&source=header ) PSoC Programmer 3.14.0.1126 and I had no trouble in programming with 5v. One option would be to change the silicon and retry. Also, can you more provide info on the programmer settings that you used? Thanks, srim |
嗨,Spiderkenny,
经过一些调查,官方的回答是: 如果你检查PSOC 5族数据表中的任何一个,你会发现2个参考电压对NVLS编程的要求,也被称为WOL只写锁存器。 第9.7章关于设备安全性将电压限制到VDDD & lt;=3.3V和10C-40C的温度范围。 第11章7.4只是一个表,它指定了2.7V Vdddmin和3.3V VDDD max,用于写入WOLS。 我希望这说明程序员为什么会发出这个错误消息。 罗伯特 以上来自于百度翻译 以下为原文 Hi Spiderkenny, After some investigation here is the official answer: If you check any of the PSoC 5 family datasheets, you will find 2 references to the voltage requirements for programming the NVLs or also called WOL write only latches. Chapter 9.7 about device security limits the voltage to Vddd <= 3.3V and a temp range of 10C-40C. Chapter 11.7.4 is just one table which specifies 2.7V Vdddmin and 3.3V Vddd max for writing to the WOLs I hope this clarifies why the programmer issues this error message. Robert |
谢谢你的回复。
据我所知,我没有编写任何WOL或NVLs。 我已经检查了PSoC 5编程规范手册(文件#:001-64359启。*e)声明如下: WO NVL编程是一个可选的步骤,只需要设备安全功能来启用应用程序所需的。对于正常编程,此步骤可以忽略。 我有我的计划没有改变,并没有使装置安全性的特点,所以我不知道是从哪来的。 以上来自于百度翻译 以下为原文 Thanks for the reply. As far as I know I am not programming any of the WOL or NVLs I had checked the PSoC 5 Programming Specifications manual (Document #: 001-64359 Rev. *E) which stated this: The WO NVL programming is an optional step and is required only for applications that require the Device Security feature to be enabled. This step can be ignored for normal programming. I have made no changes to my project, and have not enabled the device security features, so I'm not sure where this is coming from. |
你好,
我遇到了完全相同的问题。需要尽快支持。 在使用中:PSoC DeVik01与PSoC 5模块,5V电源 程序员参数:模式复位,验证,自动检测,连接器10P,时钟速度1.6MHz 程序员特性:协议标签JTAG,电压5.0V 程序员输出: 程序完成于14:50:21失败!用户NVLS更新失败。此操作可仅在电压范围1.8~3.3 V内完成。擦除警告!&启用调试模式,这应该在生产之前从PSoC Creator关闭。在调试模式下,闪光灯的安全设置没有被编程,所以行保护。装置设置在14:50:20262144 cy8c5588axi-060闪光bytesdevice家庭设置cy8c55xx在14:50:20自动检测装置:cy8c5588axi-060program要求14:50:19成功连接到miniprog3 / 1014dd000476在14:50:15miniprog3 2.05版[ 3.08 / 2.04 ]在14:50:14开口谢谢 奥利弗 以上来自于百度翻译 以下为原文 Hi, I ran into the exact same problem. Need support as soon as possible. In use: PSoC DevKit001 with PSoC 5 Module, 5V supply Programmer parameters: Mode Reset, Verification on, Auto detection on, Connector 10p, Clock speed 1.6MHz Programmer characteristics: Protocoll JTAG, Voltage 5.0V Programmer output: ActionsResultsProgram Finished at 14:50:21 FAILED! User NVLs update failed. This operation can be completed in voltage range 1.8 - 3.3 V only. Erase SucceededWARNING!--->Debug mode enabled, this should be turned off from PSoC Creator before production. In debug mode, flash security settings are not programmed, so all rows are unprotected.Device set to CY8C5588AXI-060 at 14:50:20262144 FLASH bytesDevice Family set to CY8C55xx at 14:50:20 Automatically Detected Device: CY8C5588AXI-060Program Requested at 14:50:19 Successfully Connected to MiniProg3/1014DD000476 at 14:50:15MiniProg3 version 2.05 [3.08/2.04]Opening Port at 14:50:14 Thanks Oliver |
对不起我的急躁。我在这里找到了答案:
重新编程我的PSoC5不再可能与最新的程序员?VVSK发布在23马尔2012 01:50上午PST赛普拉斯员工21论坛论坛HI AbjjIT, 结果发现,用户的NVL在PSoC 5硅中的耐久性与器件的工作电压有关,所需的电压范围被发现是1.8~3.3 V。因此,决定在PSOC 5器件的生产硅中,我们不会对用户NVL进行编程。s,并将它们设置在默认值集上。所有新的PSoC 5样本都有默认的NVL设置。但是已经与客户在现场的设备可能有不同于默认设置的NVL设置。所以PSoC的程序员试图恢复值为默认值编程时这些设备的第一次。而这一次规划,预计1.8-3.3 V工作电压。但是一旦你有默认值的程序,编程的下一个尝试不需要NVL编程就不需要3.3V的限制。 底石灰是, 现有的PSoC 5样品(与沙一段他们的标志)已经在使用的客户将需要一个3.3 V规划一旦恢复Th NVL的万一他们有不同的价值观的默认值。 生产的PSoC 5样品(无沙一段他们的标志)在编程过程中对VDDD电压没有限制他们已经正确的默认值。 的PSoC 3样品没有(新的或旧的)有NVL编程的局限性。他们支持的所有设备的工作电压NVL编程。 当做, 维韦克 虽然我的问题:我需要一个3.3V电源,使我对员不可操作。 谢谢 奥利弗 以上来自于百度翻译 以下为原文 Sorry for my impatience.. i found the answer i need here: Re: Programming my PSOC5 no longer possible with latest Programmer?
Thanks Oliver |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-20 08:50 , Processed in 0.772078 second(s), Total 71, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
