嗨,我的8752C VNA显示有缺陷的A3光源,由频谱分析仪检查sma输出端口确认(在任何功率设置下小于-30 dBm)。
我追踪问题(s?)到铸铝射频部件,YIG和腔输出都很好。 输出前的最后一个陶瓷模块(我相信ALC探测器)会在连接一些金迹的某些黑色斑块(电阻器或电容器?)上显示一些物理损坏(烧伤/裂缝)。 其他模块使用双筒望远镜看起来很精致,这当然不是很多,除了一些希望它可能没问题! 我想更换有缺陷的陶瓷模块,从最后一个(ALC探测器?)阶段开始,然后可能是前一个(放大器?),我找到了一个可以清除A3射频陶瓷模块的8752A。 有人能告诉我8752A的A3源(或至少是陶瓷模块)是否相同/兼容,比如我能做到吗? 这里附有我的A3光源图片,RF铝盖打开。 非常感谢你的帮助! 让 - 吕克 - F4GEQ 以上来自于谷歌翻译 以下为原文 Hi, My 8752C VNA shows a defective A3 source, as confirmed by Spectrum Analyzer checks on the sma output port (less than -30 dBm at any power setting). I traced the problem(s?) to the cast aluminum RF part, YIG and cavity outputs being fine. The last ceramic module before output (I believe the ALC detector) shows some physical damage (burns/cracks) on some black patches (resistors or capacitors?) linking some gold traces. The other modules look visually fine using a binocular, which of course doesn't me much except some hope it might be OK!. I want to replace the defective ceramic module(s), beginning with the last (ALC detector?) stage, and then possibly the one before (amplifier?) and I have found a 8752A that I could scavenge the A3 RF ceramic modules from. Can someone tell me if 8752A have its A3 source (or at least the ceramic modules) the same/compatible, such as I can do that? Here-enclosed a picture of my A3 source, RF aluminum cover open. Many thanks for yr help! Jean-Luc - F4GEQ 附件
3个回答
Joel博士提到,你所拥有的52K应该是500欧姆。
这是20 dB衰减器,假设是与另一个端口相关的R输出,这是真正的输出。 此外,缺少的是位于该输出结的RPP二极管。 C源具有双范围输出DSS(6 GHz),而A型不具有(3 GHz)。 如果您的输出在源上损坏那么坏,则很可能RF耦合器也会损坏。 以上来自于谷歌翻译 以下为原文 Where you have the 52K should be 500 ohms as Dr. Joel mentioned. This is the 20 dB pad that is suppose to be the R output in relation to the other port which is the true output. Also, missing is the RPP diode that is at that output junction. The C source has the dual range output DSS(6 GHz), where as the A model does not(3 GHz). If your output is damaged that bad on the source, most likely the RF coupler is damaged as well. |
主输出电阻应为50欧姆。
我不打扰保护二极管。 您不太可能想出足够的替换零件。 他们是客户安捷伦束 - 引线二极管堆栈,其导通电压约为5伏。 以上来自于谷歌翻译 以下为原文 The main output resistor should be 50 ohms. I would not bother with the protection diodes. Very unlikely you could come up with adaquate replacement parts. They are customer Agilent beam-lead diode stacks with a turn on voltage of about 5 volts. |
Epilogue我在烧焦的地方焊接了一个49.9欧姆的小型0402尺寸电阻器,我在整个频率范围内观察到一个稳定的信号略高于设定值几个dB。
在使用我的hp437B功率计进行服务调整程序后,一切都恢复正常。 非常感谢,我的分析仪正在工作。 作为afternote,我在辅助设备上测量52欧姆电阻。 RF路径不是单独的电阻值:我已经意识到这个电阻器与下游的50欧姆接地电阻器和上游侧的开关耦合器的2.x欧姆电阻接地并联,即50 + 2 .x = 52欧姆。 的确,它一定是近似的。 500欧姆提供测量的信号衰减。编辑:John F4GEQ于2013年2月13日上午9:08 以上来自于谷歌翻译 以下为原文 Epilogue I welded a tiny 0402 size resistor of 49.9 Ohm in the place of the burnt one and I observed a solid signal slightly above set point by a few dB across the full frequency range. Everything went back to normal, after proceeding with the service tuning routines with my hp437B power meter. Many thanks indeed, my Analyzer is working. As an afternote, my 52 Ohm resistor measurement on the aux. RF path was not the resistor value alone: I have since realized this resistor is paralleled by the 50 Ohm ground resistor downstream, and by the 2.x Ohm resistance-to-ground of the switch-coupler on upstream side, i.e. 50+2.x= 52 Ohm. Indeed it must have been approx. 500 Ohm to provide the measured signal attenuation. Edited by: John F4GEQ on Feb 13, 2013 9:08 AM |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:52 , Processed in 1.137388 second(s), Total 74, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
