FPGA编译器生成一个比特流来配置FPGA芯片。
它是如何工作的? 在软件中,节点,源,接收器,路由由int,strcuture,链表,指针,矩阵表示, 我的意思是,在软件软件中,它没有物理线的概念,如线的形状,serpitine shpae,经过了多少转。 是的,我可以理解寄存器编程位,你只需要编程1和0来编程FPGA的配置 但我无法想象程序如何转换,因此编程芯片并使最终的电线看起来像。 软件如何控制实际的FPGA布线(形状,长度等)? FPGA布线的形状可以用C语言的链表,结构,矩阵表示吗? 以上来自于谷歌翻译 以下为原文 FPGA compiler generated a bitstream to configure the a FPGA chip. how does it work? In software, the nodes, source, sink, route are represented by int, strcuture, linked list, pointers, matrix, I mean, in softwareware it doesn't have the notion of a physical wire like the the shape of the wire, serpitine shpae, how many turns, going through.. Yes, I can understand the register programming bit where you only need to program 1's and 0's to program FPGA's configuration But I cannot imagine how the program can translate and therefore program the chip and make the final wires look like. how can softwares control actual FPGA's wirings (shape, length.etc)? Is the shape of FPGA wirings can be represented by linked list, structure, matrix of C language? |
7个回答
实施工具负责此流程
检查这些教程 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug904-vivado-implementation.pdf http://www.xilinx.com/itp/xilinx10/isehelp/ise_c_fpga_design_flow_overview.htm 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Implementation tool take care for this flow check these tutorials http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug904-vivado-implementation.pdf http://www.xilinx.com/itp/xilinx10/isehelp/ise_c_fpga_design_flow_overview.htm Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
它并没有真正回答我的问题。
让我们说在软件中,布线由int(整数)表示,但不包含电线的真实物理方面。 物理FPGA的特定网络或线路如何在软件中采用特定的形状,它只用int(整数类型)表示? 以上来自于谷歌翻译 以下为原文 it doesn't really answer my question. Let's say in software the wiring is represented by the int (integer), but that doesn't contain the real physcial aspect of the wire. How can a physical FPGA 's particular net or wire takes a particular shape when in software it's only represented by a int (integer type)? |
合成过程从hdl代码转换为逻辑http://people.sabanciuniv.edu/erkays/el310/SimSyn_03.pdfhttp://www.utdallas.edu/~zxb107020/EE6306/Tutorial/VHDL.pdf
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 conversion from hdl code to logic done by synthesis process http://people.sabanciuniv.edu/erkays/el310/SimSyn_03.pdf http://www.utdallas.edu/~zxb107020/EE6306/Tutorial/VHDL.pdfThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@lilzz
在RTL中定义逻辑后,综合工具会将描述转换为网表(单元格,网络......)。 生成的网表将由实现工具使用,MAP和PAR(ISE)将基于结构上的可用资源完成。 请参阅以下链接: http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_implement_fpga_design.htm 谢谢,Anusheel ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - - 搜索 在论坛上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关论坛并确保您的查询不会重复。请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助 回答 - >给予Kudos --------------------------------------------- -------------------------------------------------- 以上来自于谷歌翻译 以下为原文 @lilzz Once you define the logic in RTL, synthesis tool will convert the description into a netlist (cells, nets...). Generated netlist will be used by an implementation tool, MAP and PAR (ISE) will be done on the basis of available resources on the fabric. Refer below link: http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_implement_fpga_design.htm Thanks, Anusheel ----------------------------------------------------------------------------------------------- Search for documents/answer records related to your device and tool before posting query on forums. Search related forums and make sure your query is not repeated. Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
对不起,我没有说清楚。
我不是在谈论C代码中的设计。 我实际上正在研究有关MAP,placen-route工具源代码的详细信息,它是C代码。 我在这些工具中看到,网络由int(整数类型)表示。 以上来自于谷歌翻译 以下为原文 Sorry, I didn;t make it clear. I am not talking about the design in C code. I am actually studying in details about the MAP, placen-route tool source code which is in C code. I saw in those tools, the nets are represented by int (integer type). |
您可以将FPGA表示为图形,其中顶点表示LUT或DFF,其中边表示路由。
有了这个,假设您可以合成设计并从RTL获得所需的门和连接,则映射器的任务是将合成图中的顶点分配给fpga图中的顶点,并且路由器的任务是查找 有效的连接没有重叠。 映射设计与合成图具有相同的连通性(即边缘),但fpga图具有从顶点到顶点的许多可能边,并且可以跳过多个顶点以从一个节点到另一个节点。 路由器必须找到从合成边缘列表到fpga边缘列表的低成本映射。对于映射器和路由器,在时序和时间方面都存在与fpga图中使用的每个边缘相关的成本。 功率。 因此映射& 路由(最有可能)是图操作的凸优化问题。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 You can represent the FPGA as a graph where the vertices represent LUTs or DFFs and where edges represent the routing. With this, assuming you can synthesize the design and get the gates and connectivity you need from the RTL, the task of the mapper is assigning the vertices in the synthesis graph to the vertices in the fpga graph and the task of the router is to find efficient connections without overlaps. The mapped design has the same connectivity (ie edges) as the synthesis graph but the fpga graph has many possible edges from vertex to vertex and one can jump over multiple vertices to get from one node to another. The router has to find low cost mapping from the synthesis edge list to fpga edge list. For both mapper and router, there is a cost associated with each edge used in the fpga graph both in terms of timing & power. So mapping & routing is (most probably) a convex optimization problem of graph manipulation. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
lilzz写道:
对不起,我没有说清楚。 我不是在谈论C代码中的设计。 我实际上正在研究有关MAP,placen-route工具源代码的详细信息,它是C代码。 我在这些工具中看到,网络由int(整数类型)表示。 在计算机世界中,任何东西都可以用1和0表示。 你试图重新发明轮子还是什么? ...似乎您可能需要进一步回顾FPGA历史的旧日 正如其他人所指出的那样,FPGA的名字就是“现场可编程门阵列”器件,FPGA本身已经有了逻辑,盒子,开关,wrires等阵列......它们已经准备好连接成有用的电路 现在来到有趣的部分如何构建您的电路,在过去的日子里我们仍然使用orcad原理图作为设计输入工具来告诉FPGA如何连接那些电线,LUT ......以及其他人甚至挖掘芯片来做手册 路由(幸运的是我没有),....当然有一个非常好的引擎可以将设计输入表格翻译成设备可以理解或可配置的格式,因为我记得Xilinx称之为M1引擎,不知道他们有什么 在那之前 以上来自于谷歌翻译 以下为原文 lilzz wrote:In the computer world anything can be represented by 1s and 0s , period. Do you try to reinvent the wheel or what ? ... it seems you may need to look further back into the old day of FPGA history Like other has pointed out, the FPGA as its name suggested is the "field programmable gate array" device, the FPGA by itself already had the arrays of logics, boxes, switches, wrires ... those are ready to be connected into useful circuits Now come the fun part how to build your circuit, back in the old day we still using orcad schematic as design entry tool to tell the FPGA how to connect those wire, LUTs ...and others even digged in the chip to do the manual routing (luckily me not), .... of course there is an ingenious engine behind to translate the design entry form into the format the device can understand, or configurable, as I recall Xilinx call it the M1 engine, not sure what they had before that |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 18:34 , Processed in 1.102897 second(s), Total 78, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
