大家好,
市场上是否有可用于连接FMC连接器的FMC电缆。 我担心xilinx将不再支持其他IO连接器。 FPGA怪胎 以上来自于谷歌翻译 以下为原文 Hi all, Is there any FMC cables available in the market to connect with the FMC connector. I am afraid that xilinx will not support other IO connectors anymore. FPGA freak |
13个回答
FMC设计用于板对板连接,其中一块板作为“载体”,一块板作为“夹层”。
FMC标准定义了许多项目是单向的,如I2C PROM,电压电源,时钟,MGT等,不适合尝试将电缆从一个载波(如ML605)连接到另一个载波 。 FMC模块(如FMC-XM101)提供了一种通过高性能电缆将两个载卡连接在一起的方法。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 FMC is designed for a board-to-board connections with one board as the "carrier" and one as the "mezzanine". The FMC standard defines a number of items that make are uni-directional like I2C PROM, Voltage Supplies, Clocks, MGTs, etcc that don't fit in well with trying to connect a cable from one carrier, like a ML605, to another carrier. FMC modules such as the FMC-XM101 provide a way to be able to connect two carrier cards together over high performance cables. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
>>> FMC模块(如FMC-XM101)提供了一种通过高性能电缆连接两个载卡的方法。
因此,我们可以使用FMC电缆连接两块电路板。或者将载板连接到mezzine,因为LCD模块连接到Avnet Spartan-6 LX16评估套件中的基板 FPGA怪胎 以上来自于谷歌翻译 以下为原文 >>>FMC modules such as the FMC-XM101 provide a way to be able to connect two carrier cards together over high >>>performance cables. So, we can connect two boards with the FMC cable.or the carrier board should be connected to the mezzine as LCD module connected to the base board in Avnet Spartan-6 LX16 Evaluation Kit FPGA freak |
sridar写道:
>>> FMC模块(如FMC-XM101)提供了一种通过高性能电缆连接两个载卡的方法。 因此,我们可以使用FMC电缆连接两块电路板。或者将载板连接到mezzine,因为LCD模块连接到Avnet Spartan-6 LX16评估套件中的基板 不,没有“FMC”电缆这样的东西。 FMC子板有某种电缆连接器,可用于连接另一个类似的子板。 但是电缆本身并不是“FMC电缆”。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 sridar wrote: No, there is no such thing as an "FMC" cable. The FMC daughter board has some kind of cable connector which can be used to connect to another similar daughter board. But the cable itself is not an "FMC Cable." ----------------------------Yes, I do this for a living. |
由于FMC模块FPGA的可用性有限,未来是否有机会使用这种电缆
以上来自于谷歌翻译 以下为原文 Is there any chance for such cables in the future, because of limited availablility of FMC modules FPGA freak |
sridar写道:
由于FMC模块的可用性有限,未来是否有机会使用此类电缆 令人怀疑,因为连接器不是为这种用途而设计的。 您可以随时询问Samtec是否有适配器板,或者您可以做我已经完成的工作 - 制作适配器板。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 sridar wrote:Doubtful, since the connector is not designed for such use. You could always ask Samtec if there's an adapter board, or you could do what I've done -- have an adapter board fabricated. ----------------------------Yes, I do this for a living. |
但不幸的是,除了FMC连接器之外,spartan sp 601板(我们正在购买)中没有太多的IO引脚。
FPGA怪胎 以上来自于谷歌翻译 以下为原文 But unfortunately, there are not much IO pins in the spartan sp 601 board (which we are buying) apart from FMC connector. FPGA freak |
我不确定“FMC模块的有限可用性”是什么意思,或者为什么你认为需要“FMC电缆”。
请提供您想要做的更多详细信息。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 I'm not sure what you mean by "limited availability of FMC modules" or why you think that a "FMC cable" is necessary. Please provide more details on what you want to do. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
通常,我们将FPGA板与ADC,DAC,GPIO等外部电路连接。
我们想对spartan-6 sp601板做同样的事情,但是板上没有太多的IO。 FPGA怪胎 以上来自于谷歌翻译 以下为原文 Generally we will be interfacing the FPGA board with an external circuitry like ADC,DAC,GPIO. We want to do the same with the spartan-6 sp601 board, but there are not much IO in the board. FPGA freak |
如果您是通常需要高性能链路的ADC或DAC接口,那么这些组件应放在FMC模块上。
现在有几个这样的,或者你可以自己设计一个。 我不清楚“FMC电缆”如何能够解决将SP601连接到这些设备的问题。 对于GPIO,FMC-XM105卡可满足您的所有需求。 http://www.xilinx.com/fmc ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 If you are interface with an ADC or DAC that generally needs to be a high performance link, so these components should be placed on a FMC module. There are several of these now available, or you could design one yourself. It isn't clear to me how a "FMC cable" would be able to solve the problem of connecting the SP601 to these devices. For GPIO, the FMC-XM105 card will meet all of your needs. http://www.xilinx.com/fmc ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
设计我自己的FMC ADC / DAC接口可以解决我的问题。
谢谢。 FPGA怪胎 以上来自于谷歌翻译 以下为原文 Designing of my own FMC ADC/DAC interface would solve my problem. Thanks. FPGA freak |
我相信SAMTEC出售这种电缆。
去他们的网站,看看它在那里 以上来自于谷歌翻译 以下为原文 i believe SAMTEC sells the cable. Go to their website and take a look, its there |
嗨,
你能说明一下电缆的名字吗? 我在samtec网站上找不到它。 以上来自于谷歌翻译 以下为原文 Hi, Can you please specify name of cable?? I couldn't find it on samtec website. |
sha @ hysCheck以下链接&
您应该联系Samtec以获取您的具体要求 https://www.samtec.com/cables/high-speed/assemblies/searay -------------------------------------------------- -------------------------------------------------- ----------------没有一个愚蠢的问题。 随意问,但快速搜索,以确保它还没有得到解答。 保持对话,获得Kudos和Accept Solution。 -------------------------------------------------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 sha@hys Check the below link & you should contact Samtec for your specific request https://www.samtec.com/cables/high-speed/assemblies/searay -------------------------------------------------------------------------------------------------------------------- There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered. Keep conversing, give Kudos and Accept Solution when you get one. ----------------------------------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-19 21:14 , Processed in 1.055937 second(s), Total 81, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
