#include "sys.h"#include "usart.h"#include "delay.h"#include "malloc.h"#include "spi.h"#include "lcd.h"#include "stmflash.h"#include "touch.h"#include "24l01.h"#include "includes.h" //开始任务#define START_TASK_PRIO 10//开始任务的优先级设置为最低#define START_STK_SIZE64//设置任务堆栈大小OS_STK START_TASK_STK[START_STK_SIZE];//任务堆栈void start_task(void *pdata);//任务函数
//无线发送任务#define WIRELESSTRANSMIT_TASK_PRIO 6#define WIRELESSTRANSMIT_STK_SIZE 64OS_STK WIRELESSTRANSMIT_TASK_STK[WIRELESSTRANSMIT_STK_SIZE];void wirelesstransmit_task(void *pdata); //触摸屏任务#define TOUCH_TASK_PRIO 4 //设置任务优先级#define TOUCH_STK_SIZE 64//设置任务堆栈大小OS_STK TOUCH_TASK_STK[TOUCH_STK_SIZE];//任务堆栈void touch_task(void * pdata);//任务函数 //画点任务#define DRAWPIONT_TASK_PRIO 8#define DRAWPIONT_STK_SIZE 64OS_STK DRAWPOINT_TASK_STK[DRAWPIONT_STK_SIZE];void drawpoint_task(void * pdata); //无线接收任务#define WIRELESSRECEIVE_TASK_PRIO 5#define WIRELESSRECEIVE_STK_SIZE 64OS_STK WIRELESSRECEIVE_TASK_STK[WIRELESSRECEIVE_STK_SIZE];void wirelessreceive_task(void *pdata); //OS_EVENT msg_key;//按键消息邮箱OS_EVENT * q_msg1;//消息队列1,用于触摸屏任务和无线发送通信OS_EVENT * q_msg2;//消息队列2,用于无线接收和画点的通信OS_TMR * tmr1;//软件定时器1void * MsgGrp1[256];//消息队列1存储地址,最大支持256个消息void * MsgGrp2[256];//消息队列2存储地址,最大支持256个消息//软件定时器1的回调函数//没100ms执行一次,用于显示CPU使用率和内存使用率void tmr1_callback(OS_TMR *ptmr,void *p_arg){static u16 cpuusage=0;static u8 tcnt=0;POINT_COLOR=BLUE;if(tcnt==5){LCD_ShowxNum(182,10,cpuusage/5,3,16,0);//显示CPU使用率tcnt=0;cpuusage=0;}cpuusage+=OSCPUUsage;tcnt++;LCD_ShowxNum(182,30,mem_perused(SRAMIN),3,16,0);//显示内存使用率LCD_ShowxNum(182,50,((OS_Q*)(q_msg1->OSEventPtr))->OSQEntries,3,16,0X80);//显示队列1当前的大小LCD_ShowxNum(182,70,((OS_Q*)(q_msg2->OSEventPtr))->OSQEntries,3,16,0X80);//显示队列2当前的大小}//加载主界面void ucos_load_main_ui(void){LCD_Clear(WHITE);//清屏POINT_COLOR=BLUE;//设置字体为蓝色 LCD_ShowString(150,10,200,16,16,"CPU: %"); LCD_ShowString(150,30,200,16,16,"MEM: %"); LCD_ShowString(150,50,200,16,16,"Q1 :000");LCD_ShowString(150,70,200,16,16,"Q2 :000");delay_ms(300);}void delay(u8 x){u8 a,b;for(a=0;a OSInit(); //初始化UCOSII OSTaskCreate(start_task,(void *)0,(OS_STK *)&START_TASK_STK[START_STK_SIZE-1],START_TASK_PRIO );//创建起始任务OSStart();} //开始任务void start_task(void *pdata){OS_CPU_SR cpu_sr=0;u8 err;pdata=pdata;q_msg1=OSQCreate(&MsgGrp1[0],256);//创建信号量q_msg2=OSQCreate(&MsgGrp2[0],256);OSStatInit();//初始化统计任务,这里会有1s左右的延时 tmr1=OSTmrCreate(10,10,OS_TMR_OPT_PERIODIC,(OS_TMR_CALLBACK)tmr1_callback,0,"tmr1",&err);//100ms执行一次OSTmrStart(tmr1,&err);//启动软件定时器OS_ENTER_CRITICAL();OSTaskCreate(drawpoint_task,(void *)0,(OS_STK *)&DRAWPOINT_TASK_STK[DRAWPIONT_STK_SIZE-1],DRAWPIONT_TASK_PRIO);OSTaskCreate(wirelessreceive_task,(void *)0,(OS_STK *)&WIRELESSRECEIVE_TASK_STK[WIRELESSRECEIVE_STK_SIZE-1],WIRELESSRECEIVE_TASK_PRIO);OSTaskCreate(wirelesstransmit_task,(void*)0,(OS_STK *)&WIRELESSTRANSMIT_TASK_STK[WIRELESSTRANSMIT_STK_SIZE-1],WIRELESSTRANSMIT_TASK_PRIO);OSTaskCreate(touch_task,(void *)0,(OS_STK *)&TOUCH_TASK_STK[TOUCH_STK_SIZE-1],TOUCH_TASK_PRIO);OSTaskSuspend(START_TASK_PRIO);//挂起任务OS_EXIT_CRITICAL();} //触摸屏任务void touch_task(void * pdata){u8 xoy_index=0;short *p;u8 err;p=mymalloc(SRAMIN,32);//申请32个字节的内存if(!p){OSTaskSuspend(TOUCH_TASK_PRIO);// 申请失败,则挂起任务}while(1){tp_dev.scan(0);if(tp_dev.sta & TP_PRES_DOWN)//触摸屏被按下{if(!(tp_dev.x >150 && tp_dev.y<100)){TP_Draw_Big_Point(tp_dev.x,tp_dev.y,RED);//画图p[xoy_index++]=tp_dev.x;//将字节存入数组p[xoy_index++]=tp_dev.y;if(xoy_index==16)//32个字节已满,可以发送了{xoy_index=0;err=OSQPost(q_msg1,(void *)p);//发送队列if(err!=OS_ERR_NONE)//发送失败{myfree(SRAMIN,p);//释放内存OSTaskSuspend(TOUCH_TASK_PRIO);//挂起任务}p=mymalloc(SRAMIN,32);//再申请32个字节的内存用于存放坐标if(!p){OSTaskSuspend(TOUCH_TASK_PRIO);// 申请失败,则挂起任务}}delay_ms(2);}}else delay_ms(10);//没有按键按下的时候}} //无线发送任务void wirelesstransmit_task(void *pdata){OS_CPU_SR cpu_sr=0;u8 *p;u8 err;u32 retry;while(1){p=OSQPend(q_msg1,0,&err);//获取要发送的包OS_ENTER_CRITICAL();//进入临界区NRF24L01_TX_Mode();//发送模式while(NRF24L01_TxPacket(p)!=TX_OK && retry<150)//发送数据{retry++;delay(1);}OS_EXIT_CRITICAL();//退出临界区myfree(SRAMIN,p);//即使是没有发送完成,也丢掉delay_ms(5);}} //无线接收任务void wirelessreceive_task(void *pdata){OS_CPU_SR cpu_sr=0;u8*p;u8 err;p=mymalloc(SRAMIN,32);//申请32个字节的内存if(!p){OSTaskSuspend(WIRELESSRECEIVE_TASK_PRIO);// 申请失败,则挂起任务}while(1){NRF24L01_RX_Mode();if(NRF24L01_RxPacket(p)==0)//一旦接收到信息,则送进消息队列2{err=OSQPost(q_msg2,(void *)p);//发送队列if(err!=OS_ERR_NONE)//发送失败{myfree(SRAMIN,p);//释放内存OSTaskSuspend(WIRELESSRECEIVE_TASK_PRIO);//挂起任务}}delay_ms(5);}}//画点函数void drawpoint_task(void * pdata){OS_CPU_SR cpu_sr=0;short *p;u8 i;u8 err;while(1){p=(short *)OSQPend(q_msg2,0,&err);//请求队列for(i=0;i<16;i=i+2){TP_Draw_Big_Point(p,p[i+1],RED);//画点}myfree(SRAMIN,p);//释放内存delay_ms(2); }} 这是在UCOSII下的无线传书,可以实现一个板子上写,两个板子上同时显示,但是当两个板子同时写的,写的半中间就会有一个板子的无线接收接收不到数据。这是为什么啊?大神求解 |
7个回答
仿真,慢慢找问题。
回复【2楼】发烧友:
----------------------------- 仿真结果就是收不到数据,进了无线接收的那个函数,接收状态的那一位就始终不置位。我奇怪的是两个板子同时画图就会出现那种情况,一个写完一个写就不会出现那种情况。搞不懂 |
碰撞了吧,你这样可能A,B同时发送,导致都不能收到应答。
厄,可是最后的结果是一个正常,一个出问题。这就郁闷了。更郁闷的是:收不到的那个软件复位还不行,必须断开电源开关,然后重启才行。这是为什么?
还有一个问题,就是我想在这个程序里加上输出三路SPWM波,但是发送数据那段又必须屏蔽掉所有中断,导致定时器中断的定时根本不准。这应该怎么办呢?操作系统就是这点麻烦,任务可以随意屏蔽中断,使需要精确定时的任务根本没有办法执行。针对这个问题,原子哥有什么好办法呢? |
这就不太清楚了,呵呵。
楼主,能不能上工程文件?
只有小组成员才能发言,加入小组>>
683 浏览 1 评论
2113 浏览 5 评论
2420 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2186 浏览 6 评论
2158 浏览 7 评论
使用eim外接fpga可是端口一点反应都没有有没有大哥指点一下啊
307浏览 9评论
295浏览 7评论
请教大神怎样去解决iMX6Q在linux3.0.35内核上做AP失败的问题呢
431浏览 6评论
295浏览 5评论
344浏览 5评论
GMT+8, 2024-4-18 19:08 , Processed in 0.858740 second(s), Total 81, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
