当我们购买PSG 8267D时,我很失望ADS中没有可用的驱动程序。对于PSG 8267C有...但我希望这也是D版本的情况。有一个解决方法所以我们可以使用
PSG 8267D在ADS环境中???? 以上来自于谷歌翻译 以下为原文 As we bought the PSG 8267D I was disappointed that there was no driver available in ADS. For the PSG 8267C there is... but I hope this will also be the case for the D version. Is there a workaround so we can use the PSG 8267D in the ADS environment???? |
1个回答
好消息,从ADS 2006(我们的最新版本)开始,使用Ptolemy Instruments库中的CM_ESG_E4438C_Sink组件支持PSGD E8267D。
该组件足够智能,可以确定您连接到哪个型号并使用适当的驱动程序。有关详细信息,请参阅以下内容:“ADS 2006A连接管理器(CM):除现有的Ptolemy接收器以下载信号到安捷伦 E4438C(ESGC)和E8267C(PSG-C)来源,ADS CM是否也支持以下当代安捷伦资源的链接:E8267D(PSG-D)和N5182A(MXG)?“:https://edasupportweb.soco.agilent。 com / portal / page?_pageid = 36,39953& _dad = portal& _schema = PORTAL& itemid = 270783& search = E8267D& ref = searchRegards,Mark(EEsof ADS技术支持工程师) 以上来自于谷歌翻译 以下为原文 Good news, as of ADS 2006 (our latest release), the PSGD E8267D is supported using the CM_ESG_E4438C_Sink component in Ptolemy Instruments library. The component is smart enough to determine what model number you have connected to it and employ the appropriate driver. See the following for more details: "ADS 2006A Connection Manager(CM): In addition to the existing Ptolemy Sinks to download signals to the Agilent E4438C (ESGC) and E8267C (PSG-C) sources, does ADS CM also support links to the following contemporary Agilent sources: E8267D (PSG-D) and N5182A (MXG)?": https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&_schema=PORTAL&itemid=270783&search=E8267D&ref=search Regards, Mark (EEsof ADS Tech Support Engineer) |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 13:01 , Processed in 1.179192 second(s), Total 74, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
