我需要用一个18F45 50尽快切换FET。有了内部(8MHz)时钟,我被限制在31250Hz。我用数据表将一个48 MHz晶体连接到10pF电容器上(数据表只给出了20MHz的电容器例子),并配置了PIC来高速运行外部晶体(HS)。理论上,48 MHz的FoSC应该给出最大的PWM频率为48 MHz / 256=187500赫兹,但我只得到62500赫兹。如果我拔掉水晶,PIC回复到它的内部振荡器,所以我必须把它设置好。我用的是18F45,因为这是我在其他地方用的手。我用CooRoft沃尔顿乘法器级制作一个升压电路,如果任何物体感兴趣,从10V获得600伏。
以上来自于百度翻译 以下为原文 I am needing to switch a FET as quick as possible with a 18F4550. With the internal (8Mhz) clock I am limited to 31250Hz. I hooked up a 48Mhz crystal as per datasheet using 10pF capacitors to ground (datasheet only gives capacitor example up to 20Mhz) and configured the PIC to run the external crystal at high speed (HS). In theory the 48Mhz FOSC should give a maximum PWM frequency of 48Mhz / 256 = 187500Hz but I am only getting 62500Hz. The PWM isn't limited surely? If I unplug the crystal, the PIC reverts back to its internal oscillator so I must have that set up fine. I am using a 18F4550 because it is what I have to hand as I use it elsewhere. I am making a boost circuit with cockroft-walton multiplier stages to get 600V from 10V if any body is interested. Attachment(s) main.c (8.58 KB) - downloaded 88 times |
3个回答
真正地?HS型振荡器的Maximum Fosc为25 MHz,PWM频率受Fosc的限制,即最大PWM频率为(FoCC/4)。
以上来自于百度翻译 以下为原文 Really? Maximum Fosc for HS oscillator mode is 25 MHz. The PWM frequency is limited by Fosc; that is, the max PWM frequency is (Fosc/4). |
谢谢你的回复。好吧,我明白了,我需要为电子元器件设置PIC,而不是水晶,我需要一个振荡器作为一个引脚是CKOUT。所以我仍然可以使我希望的PWM频率…你是一个很大的帮助!
以上来自于百度翻译 以下为原文 Thanks for the reply. Ok I see, I need the PIC to be set for EC but instead of a crystal I need an oscillator as one of the pins is CLKOUT. So I still can make the PWM frequency I desire...you have been a great help! |
您可以使用低频晶体和内部锁相环来实现一个48 MHz的FoSC值。
以上来自于百度翻译 以下为原文 You can use a lower frequency crystal and the internal PLL to achieve an Fosc value of 48Mhz. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
460浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1797浏览 0评论
GMT+8, 2024-4-24 10:47 , Processed in 1.137630 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
