你好,
我使用PSoC3来实现一些模拟滤波器和其他子电路。这些滤波器,当然,包括OAS和无源元件,如电阻器和电容器。据我所知,在PSoC Creator中实现电阻是不可能的,对吗?电容器呢?有没有机会实现“内部”PSoC3? 谢谢。当做。 以上来自于百度翻译 以下为原文 Hello, I am using Psoc3 in order to implement some analog filters and other subcircuits. These filters, of course, consist of OAs and passive components such as Resistors and Capacitors. As far as I know, it is not possible to implement Resistors in PSoC Creator, am I right? And what about Capacitors? Is there any chance to implement "inside" PSoC3? Thanks. Regards. |
2个回答
PSOC3中有电容器和电阻器。在CT块中与CT Opamaps结合的电阻组通常用于实现PGA(可编程增益放大器)、跨阻放大器(TIA)和类似电路。电容器通常与SC块一起使用,以实现诸如混频器之类的组件。采样保持等。这些不能用作分立电容器。
但是请注意,PSOC3中可用的4个opAMAP可以用于实现滤波器。然而,请查看Opamp的带宽特性,如果它适合你的需要。这可以在PSoC3数据表或OPAP组件数据表中找到。 以上来自于百度翻译 以下为原文 There are capacitors and resistors in PSoC3. The resistor bank available in the CT block in combination with Opamaps in the CT block is typically used to implement PGA(Programmable Gain Amplifier), TransImpedance amplifier(TIA) and similar circuits. The capacitors are typically used with the SC blocks to implement components such as Mixer. Sample Hold and so on. These can not be used as discrete capacitors. However note that the 4 Opamaps available in PSoC3 can be used to implement filters. However please look in to the bandwidth characteristics of the Opamp if it suits your need. This can be found in PSoC3 datasheet or Opamp component datasheet. |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-18 21:26 , Processed in 0.693539 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
