我从您的站点下载了1136软件包(ff1136_5vlx110_ibis.pkg)的ibis-model virtex5.ibs和pkg-model。
我想将这些模型用于HyperLinx模拟器(Boardsim)。 但我不明白 - 如何将这些模型结合使用。 请帮帮我怎么做。 以上来自于谷歌翻译 以下为原文 I downloaded ibis-model virtex5.ibs and pkg-model for 1136 package(ff1136_5vlx110_ibis.pkg) from your site. I want to use these models to the HyperLinx simulator(Boardsim). But I don't understand - how to use these models together. Please, help me how to do it. |
3个回答
如果您完成了设计,请从ISE生成设计特定的IBIS模型,将包含包文件。
更多细节: http://www.xilinx.com/support/answers/21632.htm -------------------------------------------------- -------------------------------------------------- --------不要忘记回复,kudo,并接受为解决方案.---------------------------- -------------------------------------------------- --------------------------- 以上来自于谷歌翻译 以下为原文 If you have your design done, generate the design specific IBIS model from ISE, the package file will be included. More details: http://www.xilinx.com/support/answers/21632.htm ------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. --------------------------------------------------------------------------------------------------------- |
我想在搜索有关IBIS建模的信息时看到我见过的这个AR21632。
不幸的是,链接被破坏,当我搜索21632时,我得到的是在论坛中对它的引用。 这非常令人沮丧...... 如果这个AR21632已经被重新提供,因为它不再准确,我想了解如何执行此操作的当前信息 以上来自于谷歌翻译 以下为原文 I would like to see this AR21632 that I've seen references to when searching for information on IBIS modeling. Unfortunately the link is broken and when i search for 21632 all I get are references to it in the forums. This is highly frustrating.... if this AR21632 has been remived because it is no longer accurate, I'd like the current information on how to do this |
elizabeth_simon@selinc.com
使用自定义IBIS文件(IBISWriter实用程序)时: 在ISE内: 1.在“进程”窗口中:2。 展开实现设计树。 展开布局布线树。 右键单击Generate IBIS Model并选择Properties.5。 启用复选框生成详细包寄生参数。 双击生成IBIS模型以创建输出文件 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 elizabeth_simon@selinc.com When using the custom IBIS file (IBISWriter utility): Within ISE: 1. In the Processes window: 2. Expand the Implement design tree. 3. Expand the Place and Route tree. 4. Right-click Generate IBIS Model and select Properties. 5. Enable checkbox Generate Detailed Package Parasitics. 6. Double-click Generate IBIS Model to create to output file -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2078 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1640浏览 0评论
GMT+8, 2024-4-24 10:35 , Processed in 1.046101 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
