您好,首先我要说的是,我非常新的PIC编程。我已经更改了一个源代码(从PIC10F202),以便PIC10F322的同义词适合于MPLAB ID.V892。我想调试现在的调试器& gt;选择工具& gt;“MPLAB SIM”。但是在几行之后,程序崩溃了。我不知道为什么:你能帮我吗?当做
以上来自于百度翻译 以下为原文 Hello, First I would say that I'm very new with pic programming. I have changed a source code (from PIC10f202) so that synonymous to the pic10f322 fits in MPLAB IDE v8.92. I would like to debug now Debugger>select tool> "MPLAB Sim". But after a few lines later the program crashes. I don't know why :/ Can you help me? Regards |
9个回答
你是说MPLAB,模拟器还是你写的程序崩溃?
以上来自于百度翻译 以下为原文 Do you mean MPLAB, the simulator or the program you wrote crashes? |
我的意思是完全崩溃的MPLAB。然后我必须重新启动MPLAB
以上来自于百度翻译 以下为原文 I mean completely crashes the MPLAB. Then I have to restart MPLAB |
由于未更改的程序不会崩溃:在较小的步骤中进行调整是否可行?在步骤之间,让SW与模拟器一起运行……当它崩溃时,最后一步是被详细检查的罪魁祸首。BTW:它可能是你的电脑上“内存可用”的问题吗?虽然PIC存储器相当小,但是模拟需要一些内存来执行。
以上来自于百度翻译 以下为原文 As the unaltered program does not crash: would it be feasible to make your adjustments in smaller steps ? Inbetween steps making and letting the sw run with the simulator... When it crashes, the last step is the culprit to be inspected more in detail. BTW: could it be a problem of "memory available" on your PC? Though the PIC memory is quite small, the simulation requires some memory to execute. |
问题可能是MPLAB 8.92的模拟器处于10F322的β级。
以上来自于百度翻译 以下为原文 The problem may be that the simulator of MPLAB 8.92 is in beta stage for that 10F322... |
嗨,为什么你使用6年未维护的MPLAB V892而不是MPLAB X?顺便说一下,PIC10F202使用基线内核(12位指令),而PIC10F322使用MIDROLRANGE核心(14位指令)。请显示您的代码。如果它崩溃,它可能意味着你在模拟器中有一个重置,或者你忘记了C程序中的一个while循环……你的软件不应该退出主()循环。
以上来自于百度翻译 以下为原文 Hi, any reason why you use the 6 years old unmaintained MPLAB v8.92 and not MPLAB X ? By the way, PIC10F202 uses a baseline core (12 bits instructions) while PIC10F322 uses the middlerange core (14 bits instructions). Please show your code. If it crashes it probably means you have a reset generated in the simulator or you forgot a while loop in your C program....your software should never exit main() loop. Regards |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-18 12:29 , Processed in 1.403268 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
