我下载了vivado 2015.2 linux安装文件,这是一个tar.gz文件。
我该如何在linux上安装它? 这些文件显示在附带的屏幕截图中。 tar.gz文件中的哪个文件应该被执行? 谢谢。 以上来自于谷歌翻译 以下为原文 I download vivado 2015.2 linux installation file, which is a tar.gz file. How should I install it on linux? The files are shown in the attached screenshot. Which file inside the tar.gz file should be excuted? Thank you. |
7个回答
嗨,你应该执行xsetup.Thanks,Shreyas
-------------------------------------------------- --------------------------------------------尝试搜索你的答案 在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号) 并回复.---------------------------------------------- ------------------------------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, You should execute xsetup. Thanks, Shreyas---------------------------------------------------------------------------------------------- Try to search answer for your issue in forums or xilinx user guides before you post a new thread. Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos (star provided in right) to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
-------------------------------------------------- --------------------------------------------尝试搜索你的答案 在发布新帖子之前在论坛或xilinx用户指南中发出问题。请注意 - 如果提供的信息解决了您的问题,请将答案标记为“接受为解决方案”。给予您认为有用的帖子给予荣誉(右边提供的星号) 并回复.---------------------------------------------- ------------------------------------------------ 以上来自于谷歌翻译 以下为原文 Hi, You should execute xsetup. Thanks, Shreyas---------------------------------------------------------------------------------------------- Try to search answer for your issue in forums or xilinx user guides before you post a new thread. Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query. Give Kudos (star provided in right) to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
你好@ buddha1987
有关安装的详细说明,请参阅此用户指南:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @buddha1987 For detailed instruction on installation, see this user guide: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
仅供参考:Vivado 2015.2支持以下Linux O / S.
•Red Hat Enterprise Workstation 7.0(64位) •红帽企业工作站6.4-6.6(64位) •SUSE Linux Enterprise 12.0(64位) •Cent OS 7.0(64位) •Ubuntu Linux 14.04 LTS(64位) •Vivado Lab Edition是唯一支持Red Hat Enterprise的Xilinx工具集 工作站6.4-6.6,32位操作系统。 实验室版也支持64位 系统。 。 _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 FYI: The below linux O/S are supported for Vivado 2015.2. • Red Hat Enterprise Workstation 7.0 (64-bit) • Red Hat Enterprise Workstation 6.4-6.6 (64-bit) • SUSE Linux Enterprise 12.0 (64-bit) • Cent OS 7.0 (64-bit) • Ubuntu Linux 14.04 LTS (64-bit) • Vivado Lab Edition is the only Xilinx toolset that supports the Red Hat Enterprise Workstation 6.4-6.6, 32-bit Operating Systems. Lab Edition also supports the 64-bit systems. . ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
tar -xzvf $ {filename} .tar.gzhttp://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdf
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 tar -xzvf ${filename}.tar.gz http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug973-vivado-release-notes-install-license.pdfThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
2163 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2078 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2193 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
423浏览 1评论
1523浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2177浏览 0评论
508浏览 0评论
1640浏览 0评论
GMT+8, 2024-4-24 09:41 , Processed in 1.024800 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
