用作GPIO时,STM8S103F3 PB5 / SDA表现不正确
以上来自于谷歌翻译 以下为原文 STM8S103F3 PB5/SDA behaves incorrect when used as GPIO |
4个回答
嗨丹尼斯,
I2C引脚在内部配置为真开漏I / O(未实现P缓冲和保护二极管到VDD),因此无法将它们用作输出引脚 请问这些I / O上的外部上拉电阻为4.7k。 问候 mozra 以上来自于谷歌翻译 以下为原文 Hi Dennis, The I2C pins are configured as true open-drain I/O internally, (P-buffer and protection diode to VDD are not implemented) so is not possible to use them as output pins can you please check with external pull-up 4.7k on these I/O. Regards mozra |
谢谢,莫兹拉。
我现在没有使用I2C引脚来驱动74AC164M,而是使用其他普通的GPIO。一切都很好。 但我仍然使用I2C引脚(GPIO模式)来驱动其他组件,目前它们正常工作。关于你的回复''内部将I2C引脚配置为真开漏I / O(未实现P缓冲和保护二极管到VDD) '',我不知道我是否正确,使用I2C引脚作为输出有任何潜在的风险吗? 感谢致敬 以上来自于谷歌翻译 以下为原文 Thanks, Mozra. I am not using the I2C pin to drive 74AC164M now, but with other normal GPIOs. Everything is all right. But I am still using the I2C pins(GPIO mode) to drive other components, currently they work ok. Concerning to your reply ''The I2C pins are configured as true open-drain I/O internally, (P-buffer and protection diode to VDD are not implemented) '', I don't know if I am right, is there any underlying risk to use I2C pins as output? Thanks and Regards |
嗨丹尼斯,
我可以使用STM8S103F3 PD5 / PD6作为I2C SCL / SDA引脚(bit-banging方法)吗? 这是否意味着我需要根据I2C切换配置 读/写模式? //设置端口D. / * [2] 101 7 6 5 4 3 2 1 0 | | | | | | | | | | | ___________ SCL(输出)推拉输出 | | _____________ SDA(I / O)推拉输出 DDR 0 1 1 0 0 0 0 0 CR1 0 1 1 0 0 0 0 0 CR2 0 0 0 0 0 0 0 0 * / GPIOD-> DDR = 0x70; GPIOD-> CR1 = 0x70; GPIOD-> CR2 = 0x00; STM8S103F3是否支持8051 MCU准双向模式? 以上来自于谷歌翻译 以下为原文 Hi Dennis, May I use STM8S103F3 PD5/PD6 as I2C SCL/SDA pins (bit-banging approach) ? Does it mean that I need to switch their configuration according to I2C Read/Write modes ? // Setup Port D /* [2]101 7 6 5 4 3 2 1 0 | | | | | | | | | | |___________ SCL (Output) Push pull output | |_____________ SDA (I/O ) Push pull output DDR 0 1 1 0 0 0 0 0 CR1 0 1 1 0 0 0 0 0 CR2 0 0 0 0 0 0 0 0 */ GPIOD->DDR = 0x70; GPIOD->CR1 = 0x70; GPIOD->CR2 = 0x00; Does the STM8S103F3 support 8051 MCU quasi-bidirection mode ? |
丹尼斯,
你的意思是可以使用STM8S103F3 PB.4 / PB.5 正常的开漏引脚?你能告诉我如何配置他们的注册人吗? //初始端口B. / * [2] 101 7 6 5 4 3 2 1 0 | | | | | | | | | | | | _________ I2C SCL(输出)开漏输出 | | | ___________ I2C SDA(输出)开漏输出 DDR 0 0 1 1 0 0 0 0 CR1 0 0 0 0 0 0 0 0 CR2 0 0 0 0 0 0 0 0 * / GPIOB-> DDR = 0x30; GPIOB-> CR1 = 0x00; GPIOB-> CR2 = 0x00; 他们是对的吗?我错过了什么? 以上来自于谷歌翻译 以下为原文 Dennis, Do you mean that STM8S103F3 PB.4/PB.5 can be used as normal Open Drain pins ? Could you tell me how to configure their regisers ? // Init Port B /* [2]101 7 6 5 4 3 2 1 0 | | | | | | | | | | | |_________ I2C SCL (Output) Open drain output | | |___________ I2C SDA (Output) Open drain output DDR 0 0 1 1 0 0 0 0 CR1 0 0 0 0 0 0 0 0 CR2 0 0 0 0 0 0 0 0 */ GPIOB->DDR = 0x30; GPIOB->CR1 = 0x00; GPIOB->CR2 = 0x00; Are they correct ? What did I miss else ? |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
503浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
561浏览 3评论
479浏览 3评论
GMT+8, 2024-4-20 04:36 , Processed in 0.823286 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
