大家好,
我是编程的新手,刚刚开始使用AVR。 我想稍后进入FPGA,但是我将有很多计划要确定我需要什么类型的系统要求。 我想专注于Robot Visionfirst,然后再进行双足平衡。 ROS看起来很好地支持将传感器数据集中在一起,ROS在LINUX上运行。 根据我的理解,FPGA板不是单板计算机,而是可以通过PCIe插槽与PC连接。 经过大规模的谷歌研究,与所有其他类型的开发板相比,我提供的关于爱好机器人技术中使用的FPGA的信息非常少。 任何人都可以指出我在哪里寻找有关成功地将FPGA板与PC一起工作的信息的正确方向,处于业余爱好水平? 提前致谢! 以上来自于谷歌翻译 以下为原文 Hi All, I'm new to programming and have just started wtih AVR. I'd like to later venture into FPGA but will have a lot of planning to do on exactly what type of system requirements i will need. I'd like to focus on Robot Vision first, and then bipedal balance later. ROS looks like it has good support for bringing sensor data together, ROS runs on LINUX. From my understanding, FPGA boards are not single board computers, but can be interfaced with PC's through the PCIe slot. After massive google research, I've come up with very little information on FPGAs used in hobby robotics, compared to all of the other types of development boards. Can anyone point me in the right direction of where to look for information on successfully having an FPGA board work with a PC, at a hobby level? Thanks in advance! |
4个回答
E,
我建议你看看7系列Zynq主板。 该器件具有ARM Cortex(tm)双核CPU,可以直接运行linux。 Zynq板通常也用于机器人项目,因此有各种各样的大学和学校在线项目。 视觉系统也在Zynq上实现,如果你看,你会发现Zynq的视频处理应用程序的例子。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 e, I suggest you look at the 7-series Zynq boards. The device has an ARM Cortex(tm) dual core CPU, and is able to run linux directly. Zynq boards are commonly being used in robotics project, too, so there are projects on line from varios universities and schools. Vision systems are also being implemented on Zynq, and if you look you will find examples of video processing applications for Zynq. Austin Lesea Principal Engineer Xilinx San Jose |
嗨,奥斯汀,
感谢您提供的信息,我不知道这些类型的电路板,并感谢您的建议。 以上来自于谷歌翻译 以下为原文 Hi austin, Thank you for the information, I wasn't aware of those types of boards and appreciate the suggestion. |
exwhyzed写道:
经过大规模的谷歌研究,与所有其他类型的开发板相比,我提供的关于爱好机器人技术中使用的FPGA的信息非常少。 我想这是因为我认为在这个应用程序中没有特别需要使用FPGA。 您认为10美元的ARM处理器无法满足您的需求? ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 exwhyzed wrote:I suppose that's because I don't see a particular need to use an FPGA in this application. What do you think is not adequately handled by a $10 ARM processor? ----------------------------Yes, I do this for a living. |
b,
正如我的好朋友彼得·阿尔克克曾经说过的那样,“如果你能用微处理器做到这一点,就这样做吧。” 我会稍微修改一下,并说“使用Zynq的原型,如果处理器方面不能完成这项工作,你就可以利用可编程逻辑资源来满足你的需求。” Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 b, As my good friend Peter Alfke used to say, "if you can do it with a microprocessor, do it that way." I would modify that slightly, and say "prototype using Zynq, and if the processor side cannot quite do the job, you are able to utilize the programmable logic resources to meet your needs." Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 14:38 , Processed in 1.017076 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
