1 个讨论
CC Gain: data flash raw data 0x7F71205C, EVSW reading with: 10.124
Raw data (0x7F71205C) -> first two byte is for exp gain. The exp is 0x7F -> 127, so gain: (127-128-24) = -25 -> 2^(-25) The rest is the low address to high address hex read from gauge and it is big endian. Bit 7 of the MSB is used for the sign bit, but in the conversion the mantissa is considered to be shifted so the bit 7 would always be a 1, to preserve the most possible significant bits in the mantissa. So after determining the sign here, the implied high bit must be set back to one for the conversion to be correct. 0x71205C OR with 0x80 = 0xF1205C -> convert into DEC and times 2^(-25) = 15802460*2^(-25) = 0.47095 CC Gain = 4.768/x = 4.768/0.47095 = 10.124 (matches!) CC Delta: data flash raw data 0x940898C0, EVSW reading: 10.147 Raw data (0x940898C0) -> first two byte is for exp gain. The exp is 0x94 -> 148, so gain = (148-128-24) = -4 0x0898C0 OR with 0x80 = 0x8898C0 -> convert into DEC and times 2^-4 = 559500 CC delta = 5677445/x = 5677445/559500 = 10.147 Board Offset: data flash raw data 0xF6. EVSW reading : -0.27 F6 -> convert to DEC = -9. Board offset = x*0.48/16 = -9*0.48/16 = -0.27 CC Offset: data flash raw data 0xFA89, EVSW reading with new *.encr = -0.67 0xFA89 -> convert to DEC = -1398. CC offset = x*0.00048 = -1398*0.00048 = -0.67 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1897 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3647 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9372 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
675浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1771浏览 1评论
GMT+8, 2024-4-24 15:33 , Processed in 0.630836 second(s), Total 48, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
