嗨,我正在使用带有AWGN注入的Agilent N5182A MXG信号发生器,由matlab通过lan连接控制。我想使用C / N噪声模式。因为我使用多个基带发生器同步功能,我无法使用
触发类型为连续+自由(SCPI命令参考上的第319页)问题是当我改变C / N比时,信号停止播放,我需要向SG重新发送触发命令。这个场景创建 约200ms,没有信号播放。 我的应用程序无法忍受这么长时间没有信号播放。我检查了使用FREE模式时会发生什么(没有多个基带发生器同步功能),我看到没有信号的时间缩短到大约只有5ms。我是 想知道有没有办法在使用多个基带发生器同步功能时实现这种重新触发时间。谢谢提前.Elad 以上来自于谷歌翻译 以下为原文 Hi, I am using Agilent N5182A MXG Signal Generator with AWGN injection, controlled by matlab via lan connection. I want to use C/N noise mode. Because of the fact I’m using multiple baseband generator synchronization feature, I can’t use the Trigger Type to be Continuous + Free (page 319 on the SCPI Command Reference) The problem is that when I’m changing C/N ratio, the signal stops playing and I need to resend a trigger command to the SG. This scenario creates about 200ms in which no signal is being played. My application can’t stand this long time of no signal playing. I checked the what happens when using FREE mode (with no multiple baseband generator synchronization feature) and I saw that the time of no signal shrinks to about only 5ms. I’m wondering is there a way to achieve this kind of retriggering time while using multiple baseband generator synchronization feature. Thanks in advance. Elad |
1个回答
嗨 - 当AWGN设置改变(开/关,C / N比格式,C / N比)时,主源停止信号并重新启动它,这结束了MXG的同步。
这不能改变。 需要额外的时间才能再次重新同步源。 我们已经与设计团队讨论过这个问题,我们知道没有办法解决停止调制的问题。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Elad - When the AWGN setting are changed (on/off, C/N ratio format, C/N Ratio) the master source stops the signal and restarts it, which ends the synchronization of the MXGs. This can’t be changed. The additional time is required to get the sources resynchronized again. We have discussed this with the design team and we know of no method around the need to stop the modulation. Regards - |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1855 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-26 02:13 , Processed in 0.937122 second(s), Total 43, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
