大家好,我正在使用matlab通过IVI-com驱动程序控制E4438C VSG。到目前为止,我已经找到了如何加载驱动程序,连接到设备,甚至上传&
选择ARB波形。 但是,就我而言,我无法弄清楚如何打开ARB输出。 当前代码:%create objectvsg_obj = instrument.ivicom.IviRFSigGen('device_name');%initialize objectvsg_obj.Initialize('device_name',true,true,'');%set frequency& levelvsg_obj.RF.Frequency = 1E9; vsg_obj.RF.Level = 0;%load waveform,i_data& q_data预先生成 - AWGNvsg_obj.DigitalModulation.Arb.WriteWaveform( 'arb_waveform',I_DATA,q_data,假);%选择最近上传waveformvsg_obj.DigitalModulation.Arb.SelectedWaveform = 'arb_waveform';上RF outputvsg_obj.RF.OutputEnabled%转 = true;但是,此时,写入噪声未被发送出去。 我必须手动按下按钮才能让它工作。 必须有一种方法来打开它,但我找不到哪里。还有,有没有办法通过IVI-com驱动程序发送SCPI命令? 以上来自于谷歌翻译 以下为原文 Hi all, I'm using Matlab to control a E4438C VSG via the IVI-com drivers. So far, I've figured out how to load the drivers, connect to the device, and even upload & select an ARB waveform. However, I, for the life of me, cannot figure out how to turn the ARB output on. Current Code:
However, at this point, the write noise is not being sent out. I have to mannually hit the arb on button to get it to work. There's got to be a way to turn it on, but I can't find where. Also, is there a way to send SCPI commands through the IVI-com drivers? |
1个回答
嗨 - 在已配置驱动程序的情况下,您可以发送SCPI命令以打开ARB。
这是SCPI命令:[:SOUR]:RAD:ARB ON问候 - 以上来自于谷歌翻译 以下为原文 Hi - With the Driver already configured, you can sent the SCPI command to turn on the ARB. Here’s the SCPI command: [:SOUR]:RAD:ARB ON Regards - |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 08:55 , Processed in 1.152334 second(s), Total 70, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
