我们的新PM3从MPLAB X3.61升级到最新的固件,现在,它不能编程PIC16F84(相对旧的PIC),它可以编程PIC16F150 3(相对较新的PIC)。同一个PCB,与PIC16F84编程成功通过PICtiT3。最后,我怀疑最新的固件PM。3,这是MPLAB 3.61,在编程PIC16F84时有点奇怪/错误。是否有存档的PM3固件,尝试上传一些旧的尝试?有可能这样做吗?
以上来自于百度翻译 以下为原文 Our new PM3 is upgraded automaticaly to the latest firmware from MPLAB X 3.61. Now, it cannot program PIC16F884 (relatively old PIC), and it can program PIC16F1503 (relatively new PIC). The same PCB, with PIC16F884 is programmed successfuly by PICkit3. At last, I suspect that the latest firmware of PM3, that came with MPLAB 3.61, is somewhat odd / buggy when programming PIC16F884. Is there archive of PM3 firmware, to try to upload some old to try? Is it possible to do so? |
4个回答
如果你得到和旧版本的MPLAB,它将有旧的固件为PM3。我猜他们是拆分固件的。如果你把它连接到MPLAB并选择16F84,它将加载它的FimWrand,你将失去新的图片。
以上来自于百度翻译 以下为原文 If you get and old version of MPLab, it will have old firmware for the PM3. My guess is they split the firmware. If you connect it to MPLab and select the 16f884 it will load the fimware for it, and you will lose the new PICs. |
我测试了一个旧的PM3配置,创建了2010年。我们使用这个配置多年与同一PM3。然而,在升级PM3固件从MPLAB X 3.60或61之后,编程变得不可能。然后我从这个旧的配置导出了HEX文件,并创建了新的配置(使用IPE 3.61)。有了这个新的配置,编程成功了…
以上来自于百度翻译 以下为原文 I tested with an old PM3 configuration, created 2010 year. We used this configfuration for years with the same PM3. However, after upgrading PM3 firmware from MPLAB X 3.60 or 61, programming became impossible. Then I exported HEX file from this old configuration and created new configuration (using IPE 3.61). With this new configuration, the programming succeeded... |
嗨,我昨天用MPLAB X V3.61.更新了我的PM3。它有很多不同的家庭菜单。我很确定PM3仍然可以编程你的PIC,但是它可能在另一个PM3子菜单中列出(有几个PIC16家庭提出,你可能在寻找错误的一个)。
以上来自于百度翻译 以下为原文 Hi, I updated my PM3 yesterday with MPLAB X v3.61. It has many different menus with different families. I am quite sure the PM3 can still program your PIC, but it is probably listed in another PM3 submenu (there are several PIC16 families proposed and you may be searching the wrong one) Regards |
问题解决了。电缆问题。时间符合PM3升级,可能与内存卡损坏…
以上来自于百度翻译 以下为原文 The problem is solved. Cable problems. Time coincidence with the PM3 upgrading and may be with memory card corruption... |
只有小组成员才能发言,加入小组>>
4779 浏览 9 评论
1815 浏览 8 评论
1734 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
423浏览 1评论
1101浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
345浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1751浏览 0评论
GMT+8, 2024-3-29 14:17 , Processed in 1.014735 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
