嗨,我的83650L合成器有问题。
它似乎可以达到20.000 GHz,但从20.001 GHz起,输出功率不均匀并且显着下降。 在20.001 GHz时,最大输出功率约为-14 dBm,在40 GHz时降至-100 dBm以下。 内置的自测试表明一切正常,但显然情况并非如此。 我可以访问故障排除指南和8360扫地机系列的服务指南,但我很感激任何好的想法从哪里开始寻找这个失败。 看完程序框图后我的初步猜测是它可能是RF DECK上的放大器/倍增器模块之一,但这只是一个猜测。 我还没有测量任何东西。 我希望非常突然的功率降到正好20.000 GHz以上可能会暗示一些修复8360扫地机的人会遇到什么问题。非常感谢任何helpPeter 以上来自于谷歌翻译 以下为原文 Hi, I have a problem with my 83650L synth. It seems to be ok up to 20.000 GHz but from 20.001 GHz and up the output power is unleveled and drops down significantly. At 20.001 GHz max output power is about -14 dBm and it goes down to below -100 dBm at 40GHz. The built-in selftest says that everything is working properly, but obviously this is not the case. I have access to the trouble shooting guide and the service guide for the 8360 sweeper series but i would appreciate any good ideas where to start looking for this failure. My initial guess after having a look at the block diagram is that it could be one of the amp/multiplier modules on the RF DECK, but this is so far just a guess. I have not measured anything yet. I hope the very abrupt power drop above exactly 20.000 GHz could be a hint what the problem might be for some person experienced with repairing 8360 sweepers. Many thanks in advance for any help Peter |
2个回答
嗨Peter -Your放大器/乘法器模块猜测正确.83650L有不同的频段切换到不同的YIG振荡器谐波以获得更高的频率... 20 GHz到26.5到38到50 GHz它切换到第8 YIG谐波;
射频输出应为+2.5 dBmRegards - 以上来自于谷歌翻译 以下为原文 Hi Peter - Your amp/multiplier module guess is correct. 83650L has different frequency bands that switch to different YIG oscillator harmonics to get the higher frequencies... 20 GHz to <26.5 GHz switches to the YIG 4th harmonic; RF out should be +10 dBm 26.5 to <38 GHz it switches to the 6th YIG harmonic; RF out should be +5 dBm 38 to 50 GHz it switches to the 8th YIG harmonic; RF out should be +2.5 dBm Regards - |
彼得,你的RF倍增器,5086-7607很糟糕。
它需要修理。 以上来自于谷歌翻译 以下为原文 Peter, Your RF doubler, 5086-7607 is bad. It requires repair. |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 14:35 , Processed in 1.352990 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
