有人知道如何让这个工作吗?我完全没有运气。我的问题从Bootloader开始。没有办法超越这个状态。我会宣布这件事被打破了。如果我绕过这个(只是前进到下一个状态),那么文件系统就不会挂载,文件打开失败。非常失望这些工具…如有任何帮助,我们将不胜感激。顺便说一下,使用和声V2Y02YY0B。是的,我花了几个小时与所提供的例子进行比较。这些例子根本不可能奏效!
以上来自于百度翻译 以下为原文 Does anyone know how to get this to work? I'm having absolutely no luck. My problems started in BootLoader.c with the case statement for BOOTLOADER_WAIT_FOR_DEVICE_ATTACH. There's no way to advance beyond this state. I would declare this broken. If I bypass this(just advance to the next state), then the File system never mounts, the file open fails. Very frustrated with these tools... Any help will be appreciated. BTW, using HARMony V2_02_00b. Yes, I have spent hours comparing this to the provided examples. There is simply no way that the examples have ever worked! |
5个回答
什么版本不是2.03B?什么硬件?你的?EVE板?你试过了吗?它工作在V1.11(排序)它应该在V2.xx工作。如果你是董事会。你有没有比较MHC设置到你的?代码BSP。比较程序是你的朋友。
以上来自于百度翻译 以下为原文 What not Version 2.03b? What Hardware? Yours? and Eval Board? Have you tried it on and Eval Board? It works in V1.11 (sort of) It should work in V2.XX. if it is you Board. Did you compare the MHC settings to yours? the Code the BSP. The Program Beyond compare is you friend. |
谢谢你的回复。这是我们的定制硬件。没有BSP。是的,我使用示例Bootloader文件作为起始位置,并将MHC设置复制到MIX中。这个项目从2.02B开始,我觉得没有必要更新。更改版本没有得到很好的记录。我刚刚下载和安装了1.11个你推荐的工作。Bootloader .c文件与我使用的版本2.02b相同。我仍然不知道它是如何工作的。这就是我的问题开始的地方。这在支持Bootloader的所有版本的Bootloader C中的第486行开始:CaseBootloadReWaITyFuxDeice附注:/*等待设备附加。当接收到附加事件*时,状态机将移动到下一个状态。* /打破;没有办法超越这个状态。评论是准确的,但没有代码来支持它。救命!
以上来自于百度翻译 以下为原文 Thanks for the reply. This is our custom hardware. There's no BSP. Yes, I used the example bootloader files as a starting place and duplicated the MHC settings into mine. The project started with 2.02B and I haven't felt a need to update. Changing versions is not well documented.. I just downloaded and installed 1.11 as you recommended as working. The bootloader.c file is identical (WinMerge) with the one in Version 2.02B that I have been using. I still don't see how it could work.. Here's where my problem starts. This begins at line 486 in BootLoader.c in all versions that support BootLoaders: case BOOTLOADER_WAIT_FOR_DEVICE_ATTACH: /* Wait for device attach. The state machine will move * to the next state when the attach event * is received. */ break; There's no way to advance beyond this state. The comments are accurate, but no code to support it. Help! |
嗨,正如上面的一段评论清楚地陈述了它等待设备附加事件,我想你需要看一下是否正在检测和处理UBSHEVER事件。检查这个函数“BooDouthReuleUbBuxMsDevEnthDand”是否在“DATASERAMUSSBHEST.C”中被定义。因为这是一个事件,它引导引导程序状态并枚举附加的UBSHOST设备。您试过运行由和声提供的基本演示应用程序吗?如果不尝试运行,看看它是否对您的安装工作。
以上来自于百度翻译 以下为原文 Hi, As the above section comments clearly states it waits for the device attach event, i think you need to give a look on whether the USB_HOST events are being detected and handled. Check if this function "Bootloader_USBHostMSDEventHandler"defined in "datastream_u***_host.c" is getting called. Because this is the event which moves the bootloader state forward and enumerates the USB_HOST device attached. Have you tried running the basic demo application provided by harmony? if not try to run and see if it works on your setup. |
非常感谢你的提示。它开辟了最终通向我们解决方案的道路。我没想到状态机会有外部进程的状态改变。我们的根本问题是USPPLL配置。一旦我们搞定了,事情就开始了。和谐主机2.02b中的USB主机引导加载程序好像广告一样工作。谢谢你的回复。
以上来自于百度翻译 以下为原文 Thank you very much Optimus_jack for the hint. It opened up the path that ultimately led to our solution. I wasn't expecting the state machine to have state changes made by outside processes. Our root problem turned out to be the USBPLL configuration. Once we got that fixed, things started working. The USB Host Bootloader in Harmony 2.02B seems to work as advertised. Thanks for the replies. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-19 19:09 , Processed in 1.116703 second(s), Total 77, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
