用5529进行脉宽测量,中断貌似进了但是没法判断,求解读~
#include #include "Header_Config.h" #include "sys.h" unsigned char overflow = 0,Sum_High_Index = 0,Sum_Rising_Index = 0,CCR_Flag = 0; long Wide_Rising_Old = 0,Wide_Rising_Cur = 0,Wide_Rising = 0,Wide_Rising_Sum = 0,Wide_Rising_Result = 0; long Wide_High_Cur = 0,Wide_High = 0,Wide_High_Sum = 0,Wide_High_Result = 0; void main(void) { volatile unsigned int i; WDTCTL = WDTPW + WDTHOLD; // Stop WDT Board_init(); LCD_Init(); SetVCore(3); LFXT_Start(XT1DRIVE_0); // Use 32.768kHz XTAL as reference Init_FLL_Settle(12000, 762); // Set system clock to (12MHz) SFRIFG1 = 0; SFRIE1 |= OFIE; P1DIR |= 0x01; // P1.0 output P2DIR &= ~BIT1; P2SEL |= BIT1; //P2REN |= BIT1; // Enable P1.4 internal resistance P2IFG &= ~BIT1; P2IE |= BIT1; TA1CCTL1 = CM_3 + SCS + CCIS_0 + CAP + CCIE; // 上升沿和下降沿都捕获 TA1CTL = TASSEL_2 + MC_2 + TAIE; // SMCLK, contmode, interrupt _EINT(); while(1) { if(CCR_Flag) { CCR_Flag = 0; // 捕获结果处理 Dogs102x6_numDisplay(0, 0, Wide_Rising_Result, 0); // 周期结果 Dogs102x6_numDisplay(1, 0, Wide_High_Result, 0); // 高电平宽度 } } } #pragma vector=TIMER1_A1_VECTOR __interrupt void TIMER1_A1_ISR(void) { P1OUT ^= 0x01; // Toggle P1.0 switch(__even_in_range(TA1IV,10)) { case 0: break; // No interrupt case 2: TA1CCTL1 &= ~CCIFG; if((P2IN&BIT0)==BIT0) // 上升沿引发的中断 { Wide_Rising_Cur = TA1CCR1; // 读取当前所得的最新捕获值 Wide_Rising = 65536*overflow - Wide_Rising_Old + Wide_Rising_Cur; // 防止出现溢出 Wide_Rising_Old = Wide_Rising_Cur; overflow = 0; Sum_Rising_Index++; if(Sum_Rising_Index>4) // 丢掉前几次不稳定数据 { Wide_Rising_Sum += Wide_Rising; if(Sum_Rising_Index==12) { Sum_Rising_Index = 0; Wide_Rising_Result = Wide_Rising_Sum>>3; // 得出8次捕获平均值 Wide_Rising_Sum = 0; Wide_High_Result = Wide_High_Sum/7; // 得出7次高点平捕获平均值,服务于上升沿捕获 Wide_High_Sum = 0; CCR_Flag = 1; // 置捕获完成标志位 } } } else // 下降沿引发的中断,记录高电平宽度 { Wide_High_Cur = TA1CCR1; // 读取当前所得的最新捕获值 Wide_High = 65536*overflow - Wide_Rising_Old + Wide_High_Cur; // 防止出现溢出,计算出高电平宽度 //overflow = 0; // 此处不清overflow,一个周期后清除 if(Sum_Rising_Index>4) // 丢掉前几次不稳定数据 { Wide_High_Sum += Wide_High; } } break; // CCR1 not used case 4: break; // CCR2 not used case 6: break; // reserved case 8: break; // reserved case 10: overflow++; // overflow TA1CTL &= ~CCIFG; break; // reserved default: break; } } |
1个回答
帮顶。。。。
只有小组成员才能发言,加入小组>>
2631个成员聚集在这个小组
加入小组MSP430FR5994 使用库函数 定时器触发AD问题请教
1610 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2169 浏览 1 评论
4565 浏览 1 评论
2366 浏览 1 评论
1705 浏览 1 评论
706浏览 3评论
1610浏览 2评论
930浏览 0评论
GMT+8, 2024-4-19 20:43 , Processed in 1.433253 second(s), Total 76, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
