我使用一个PIC32 MX795F12微控制器和一个RN42蓝牙到UART模块。我可以发送文本到UART,在115200波特没有问题。使用P腻y,我也可以输入命令$$进入命令模式并获得CMD响应。不幸的是,我无法使用C代码进入命令模式。我这样做的命令如下:“UART3WrreEnStand($$ $$)”;“函数定义为:},当我这样做时,RN42不进入命令模式。它只是在没有CMD响应的情况下输出$$。有什么想法吗?谢谢!
以上来自于百度翻译 以下为原文 I am using a PIC32MX795F12 microcontroller together with a RN42 bluetooth to UART module. I can send text to the UART with no problem at 115200 baud. Using Putty I can also enter the command $$$ to enter the command mode and get the CMD response. Unfortunately I've not been able to enter the command mode using the C code. My command to do this is as follows: "UART3WriteString("$$$");"where the function is defined as: void UART3WriteString(const char * str) { while( *str ) { U3TXREG = *str++; while( U3STAbits.TRMT == 0 ); //wait for the transmission to be done) }} When I do this, the RN42 does not go into the command mode. It just outputs $$$ without the CMD response. Any ideas? Thanks! |
2个回答
好的,我在Microchip站点的热门话题中找到了答案。基本上我需要在发布$$ $命令之前和之后插入一个250毫秒的缓冲区。否则,RN42将不会进入命令模式。
以上来自于百度翻译 以下为原文 Ok, I found the answer in the hot topics part of the microchip site. Basically I need to insert a 250 ms buffer before and after issuing the $$$ command. Otherwise the RN42 will not enter Command mode. |
这是一个很长的历史,回到1980调制解调器的海因斯调制解调器中,虽然他们使用了“+++”和一秒钟的延迟。http://En.维基百科…org……如果你这样做,你可能需要使你的250MS延迟更长一点,或者在调用延迟之前添加一个等待TrMT。
以上来自于百度翻译 以下为原文 You got it. This has a long history, going back to Hayes modems in the 1980's, although they used "+++" and a one second delay. https://en.wikipedia.org/..._set#Hayes.27_solution Note, your transmit routine is inefficient, it prevents the PIC doing anything while the UART peripheral does the transmitting. You can make it more efficient by changing to: void UART3WriteString(const char * str) { while( *str ) { while (U3STAbits.UTXBF); //wait until room in transmit buffer U3TXREG = *str++; } } If you do this, you may need to make your 250ms delay a little longer, or add a wait for TRMT before calling the delay. |
只有小组成员才能发言,加入小组>>
4824 浏览 9 评论
1829 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2954 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
362浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1798浏览 0评论
GMT+8, 2024-4-24 18:59 , Processed in 1.142671 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
