你好,
我正在尝试通过批量模式来测量FX2LP USB芯片。为了做到这一点,我已经修改了大量的示例固件,因此它连续地填充两个输出端点(0x86x0x88),具有512个数据字节。我还改变了BulkCurror C应用程序来读取来自这两个端点的数据。我已经测量了开始和停止命令之间的时间,以及此时我能从设备中读取的字节数。我的结果是大约0.8兆字节/秒,但我期待更高的吞吐量。 我使用的是WiN-64。我如何验证系统的高速运行和不快(0.8mbytes/s好像快速度模式对我)?是否有另一个可能的原因导致这么低的速度? 谢谢,阿列克谢。 以上来自于百度翻译 以下为原文 Hi, I am trying to measure the FX2LP USB chip througput in bulk mode. In order to do so, I have modified bulk example firmware so it continiously fills the two output endpoints (0x86, 0x88) with 512 data bytes. I have also changed the BulkLoop C# application to read the data from those two endpoints. I have measured the time between start and stop commands and the number of bytes I was able to read from the device in this time. My result was about 0.8 MBytes/s, but I was expecting much higher throughput. I am using Win7-64. How can I verify that the system operates in high speed and not in fast speed (0.8MBytes/s seems like fast speed mode to me)? Is there another possible reason for such low speed? Thanks, Alexey. |
2个回答
我已经看到速度达到40MbPs。使用SULVER应用程序和CyStand固件作为SUITEUSB的一部分来进行测量。
该设备将通过描述符报告其能力,FX2LP将报告USB2.0支持,因此如果它被枚举为全速,则应该看到弹出的消息类似于能够以更高速度运行的设备,您可能希望将设备切换到高速端口。 当做, 阿南德 以上来自于百度翻译 以下为原文 I've seen speeds upto 40MBps. Use the streamer application and cystream firmware that come as part of SuiteUSB for the measurement. The device would report its capability through descriptors, FX2LP would report USB2.0 support so if it is enumerated as full-speed you should see a pop-up with a message similar to device capable of operating at higher speeds you might want to switch the device to a high-speed capable port. Regards, Anand |
非常感谢你的回复。
我发现瓶颈是嵌入的部分——填充端点。删除CPU填充的端点,并提交到USB(充满垃圾),吞吐量提高到16Mb/s,相当不错。 再次感谢。 以上来自于百度翻译 以下为原文 Thank you very much for the reply. I have found out that the bottlenack was the embedded part - filling the endpoints. Removing the endpoints filling by the CPU and just submitting to USB (filled with junk) increased the throughput to 16MBytes/s which is quite good. Thanks again. |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-19 23:53 , Processed in 0.655504 second(s), Total 70, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
