增强的中位数14BIT指令和高端16位指令MCU更新吗?在很多方面看起来都是这样。
以上来自于百度翻译 以下为原文 Are Enhanced Midrange 14bit Instruction and High End 16bit Instruction MCU's newer? It kind of looks like it in a lot of ways. |
6个回答
我最喜欢的标准中档部分是18引脚PIC16F88,28引脚PIC16F86和40引脚PIC16F87。他们的勘误表是可管理的,它们是他们的PIN计数的最高范围,并且内置了调试支持。
以上来自于百度翻译 以下为原文 My favourite standard Midrange parts are the 18 pin PIC16F88, 28 pin PIC16F886 and 40 pin PIC16F887. Their errata are manageable, they are top of the range for their pin counts, and have built in debug support. |
PIC 32是32位,有3种基本类型mm、mx和mz(按幂级数),PIC24、DSPIC、PIC30和PIC33都是16位CPU。
以上来自于百度翻译 以下为原文 The PIC 32 is 32 Bit there are 3 basic types MM, MX, and MZ ( in Power Order) the PIC24, DsPIC, PIC30 and PIC33 are all 16 bit CPUs |
16F87被16F877 A16F877 A取代,被16F8716F877旧的代替,它像1990年一样,将使我感到抱歉。但是,这似乎是你正在寻找的。如果你打算调试它,确保它支持它。ICD是新的。
以上来自于百度翻译 以下为原文 16F877 was Replaced by the 16F877A 16F877A was Replaced by the 16F887 The 16F877 is Old, it works as will as it did in the 1990's That would make me sorry. But, It seems to be what you are looking for. If you plan to Debug it, Make sure it supports it. ICDs were new back then. |
“F88非常类似于F8X系列,但没有相当先进的外围设备”我们只是在做基本的事情。轻的LED。16F88看起来像我们的MCU。我刚刚检查了两个版本的PICBASIC PRO。实验者/学生和演示(Chuck Helebuyck)。我不想把水弄脏,看看PIC电路板是否支持它们。如果需要的话,可以打开电路板/香水。
以上来自于百度翻译 以下为原文 "F88 is very similar to the 'F88x family, but doesn't have quite as advanced peripherals" We are just doing basic stuff. 'Light an LED'. 16F88 looks like our MCU. I just checked both versions of PICBasic Pro. Experimenter/Student and Demo(Chuck Helebuyck). It is supported. I am not going to muddy the water and see if Pic Circuits breakout boards support them. Can breadboard/perfboad if necessary. Have to 'Draw the line' somewhere. |
与F88的唯一重要的“GoTya”是USAT引脚不同于PIC16F628(A)(它曾经是一个受欢迎的业余爱好者PIC),所以如果你有一个板为'628 A,与串行通信,你必须做一些轨道MODS使用“F88”。Microchip和第三方供应商中的18个适合做它的PIN板,但是它很容易够到电路板。如果你有GoEclipse训练板,我会把它放在电路板区域中,并在I/O头SIL套接字中插入等效的函数引脚,在14引脚插座中没有PIC来连接电源、ICSP和任何你想要使用的车载外围设备。
以上来自于百度翻译 以下为原文 The only significant 'gotya' with the F88 is the USART pins are different from the PIC16F628(A) (which used to be a popular hobbyist PIC), so if you have a a board intended for the '628A, with serial comms, you have to do some track mods to use a 'F88 in it. Microchip and a few of the 3rd party suppliers do 18 pin demo boards suitable for it but its easy enough to breadboard. If you have the Gooligum training board, I'd just stick it in the breadboard area, and patch to the equivalent function pins at the I/O header SIL socket, with no PIC in the 14 pin socket to hook up power, ICSP and whatever on-board peripherals you want to use. |
PICBasic Pro也支持本世纪的芯片。它也可能支持增强的图片。
以上来自于百度翻译 以下为原文 Picbasic pro supports chips from this century too. It probably supports enhanced PICs too. |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1799浏览 0评论
GMT+8, 2024-4-25 10:18 , Processed in 1.340322 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
