扫一扫,分享给好友
大家好!
我尝试使用PSoC3开发键盘扫描程序,下面是代码: Posi0(1);(或)输出B11111111到PORT0PORT04(0);Poto0E6(0);PoT007(0);Tun1= PRT0DR;PoT0 0(0);Poto011(0);PoTo02(0);Tun2= PRT0DR;X= Tun1&TEMP2;开关(X){0X11: KEY=0;中断;CASE 0x21:密钥=1;中断;案例0x41:密钥=2;中断;案例0x12:KEY=5;中断;CASE 0x42:密钥=6;中断;CASE 0x14:KEY=8;中断;CASE 0x24:密钥=9;断言;CASE 0x44:密钥=10;中断;CASE 0x84:KEY=11;断言;CASE 0x18:KEY=12;中断;CASE 0x28:密钥=13;破解;案例0x48:KEY=14;SKEY;CASE 0x88:KEY=15;SUBLD;默认值:KEY=6;Burd;} 问题是8,所有的数据都是好的,LCD可以正确显示数据,但是在8之后,结果总是6,也就是默认输出,看来P0[ 2 ],P0[4]不能检测到信号,我用CY8C9466,谁能告诉我原因,非常感谢! 以上来自于百度翻译 以下为原文 Hello,everyone! i tried to use psoc3 to develop a keypad scan programa, here is the code : void KeyScan() { Port0(1); //output b11111111 to the port0 Port0_4(0); Port0_5(0); Port0_6(0); Port0_7(0); temp1=PRT0DR; Port0(1); Port0_0(0); Port0_1(0); Port0_2(0); Port0_3(0); temp2=PRT0DR; x=temp1&temp2; switch(x){ case 0x11:key=0;break; case 0x21:key=1;break; case 0x41:key=2;break; case 0x81:key=3;break; case 0x12:key=4;break; case 0x22:key=5;break; case 0x42:key=6;break; case 0x82:key=7;break; case 0x14:key=8;break; case 0x24:key=9;break; case 0x44:key=10;break; case 0x84:key=11;break; case 0x18:key=12;break; case 0x28:key=13;break; case 0x48:key=14;break; case 0x88:key=15;break; default: key=6;break; } } the problem is befor 8,all the data is good, lcd can display the data correctly,but after 8,the results is always 6,that is the default output, it seems the p0[2],p0[3] can not detect the signal,i am using cy8c29466,can anyone tell me the reason,thank you very much! |
2个回答
你能告诉我们更多关于你的硬件设置吗?也许一个原理图应该有帮助。只是使用代码,很难调试这个问题。
以上来自于百度翻译 以下为原文 Can you tell us more about your hardware setup. Possibly a schematic should help. Just with the code it is tough to debug the issue. |
我使用的是一个4×4的键盘,并将行连接到P0[0 ] -P0[3 ],列到P0[4 ] -P0[7 ];
将引脚设置为下拉模式, 问题是P0〔2〕和P0〔3〕不能得到信号,因为其他管脚工作良好。 以上来自于百度翻译 以下为原文 i am using a 4*4 keypad ,and connect the rows to P0[0]--P0[3],the columns to P0[4]--P0[7]; set the pins as pull down mode, and the problem is that it seems the P0[2] and P0[3] can not get the signal, because other pins works fine |
只有小组成员才能发言,加入小组>>
715个成员聚集在这个小组
加入小组1896 浏览 1 评论
1651 浏览 1 评论
3401 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1567 浏览 6 评论
1379 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
180浏览 2评论
179浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
318浏览 2评论
344浏览 1评论
58浏览 1评论
GMT+8, 2024-4-19 18:58 , Processed in 0.674716 second(s), Total 72, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
