发 帖
【四旋翼飞行器】76小时吃透四轴算法!史上最强软硬结合实战项目,👉戳此立抢👈
LT2611UXC重点推荐:LVDS转HDMI2.0
2019-3-16 15:41:47  26
分享
1. Description
The LT2611UXC is a high performance LVDS to HDMI2.0 converter for STB, DVD applications.
The LVDS input can be configured as single-port or dual-port with 1 high-speed clock lane, and 3~4 high-speed data lanes operating at maximum 1.2Gbps/lane, which can support a total bandwidth of up to 9.6Gbps. LT2611UXC supports flexible video data mapping path for 2D and 3D applications.
The HDMI2.0 output supports data rate up to 3Gbps which provides sufficient bandwidth for 4k@30Hz video. Also HDCP2.2 is supported for data encryption.
Two digital audio input interfaces are available, I2S and SPDIF. The I2S interface supports 2-ch LPCM and the SPDIF interface supports 2-ch LPCM or compressed audio, both at maximum 192kHz sample rate.
The device is capable of automatic operation which isenabled by an integrated microprocessor that uses an embedded SPI flash for firmware storage. System control is also available through the configuration I2C slave interface.
2. Features
• Single/Dual-Port  LVDS Receiver
• Digital Audio Input
• HDMI2.0 Transmitter
• Miscellaneous
3. Applications
• STB
• DVD/BD
• PTV Box
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?注册
x
2019-3-16 15:41:47   评论 分享淘帖
高级模式
您需要登录后才可以回帖 登录 | 注册
发表新帖
课程
    关闭
    站长推荐 上一条 /8 下一条
    快速回复 返回顶部 返回列表
