运行成功后,PSOC 3第一触摸套件的样例项目我想写我自己的第一个项目。我从LED闪光灯项目开始的文件“我的前五个设计”。我把LED的插脚拿到第一个触摸板上。当我尝试将程序加载到工具包中时:
“选定的调试目标”CY8C3666 AXA040 ES2’与项目选定的设备“CY8C3666 AXI-040生产”不兼容。 然而,CPUCY8C3666 AXI-040XI在第一个触摸样本项目中使用,尽管在板上有CPU版本“ES2”。在PSoC创建者的设备选择器中没有提供“ES2”版本。 有人知道吗? 1)AXI和ES2版本有什么不同,我从DigiKy获得了过时版本的插件板吗? 2)我如何说服PSoC创建者1(生产版本)将我的固件下载到ES2版本? 最好的问候 尤尔根普茨格 雷根斯堡大学 以上来自于百度翻译 以下为原文 After running successful the sample projects for the PSOC 3 First Touch Kit I wanted to write my first own project. I started with the LED-flash project from the document "My first five designs". I adopted the pins of the LED´s to the First Touch board. When I try to load my program into the kit I geht the mesage: "The selected debug target 'CY8C3866AXA-040 ES2' is not compatible with the project's selected device 'CY8C3866AXI-040 PRODUCTION" The CPU CY8C3866AXI-040 XI is however used In the First Touch sample projects that are working although there is a CPU version "ES2" on the board. The Version "ES2" is not offered in the device selector in PSOC Creator. Does anyone know 1.) What is the difference between the AXI and the ES2 version, did I get an outdated version of the board from Digikey ? 2.) How can I convince PSOC creator 1 (production version) to download my firmware into the ES2 version ? Best regards Juergen Putzger Universitaet Regen***urg |
2个回答
好,
我可以给出一部分答案:在设备选择器右下角有一个小下拉菜单,在那里我可以选择“ES2”版本而不是“生产版本”。这样做之后,我可以把我的固件编程到板上。 仍然是一个问题,“ES2版本”不同于“生产版本”。有什么缺点吗? 最好的问候 尤尔根 以上来自于百度翻译 以下为原文 Well, I can give part of the answer myself: There is a small pull down menue in the lower right corner of the device selector where I can select the "ES2" version instead of the "Production version". After doing so I can program my firmware into the board. Remains the question how an "ES2 version" differs from the "Production version ". Any disadvantages ? Best regards Juergen |
HelloJuergen
在PSOC3芯片被释放后,有多次修改,每个修订都有一些修正。可用的硅修订是ES1、ES2、ES3/生产,其中ES代表工程样品。ES2硅修订版有许多硅修复。ES3/生产版本硅是准备生产,并有大部分的硅修复。在你购买第一触控套件时,它是用ES2硅运输的。 CY8C3666 AXI-40是一个特定的部件号。零件号约定在设备数据表零件号约定中解释。在字符串AXI中,“AX”表示包类型是TQFP,而“I”代表工业。 正如你在以前的评论强调,在你的设备选择窗口选择的设备应为你想程序一样的装置。 我希望这有帮助。 -乌达扬 以上来自于百度翻译 以下为原文 Hello Juergen, After PSoC3 chip was released, there were multiple revisions, with each revision having some fixes. The silicon revisions available are ES1, ES2,ES3/Production, where ES stands for Engineering Samples. ES2 silicon revision had many Silicon fixes. ES3/Production version silicon is ready for production and has most of the silicon fixes. At the time you purchased First Touch Kit, it was being shipped with ES2 Silicon. CY8C3866AXI-40 is a specific Part Number. The part number convention is explained in the device datasheet Part Number Convention. In the string AXI, "AX" indicates that the package type is TQFP and " I " stands for Industrial. As you have highlighted in your previous comment, the device selected in your device selector window should be the same as the device which you are trying to program. I hope this helps. -Udayan |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
322浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-24 23:17 , Processed in 0.669419 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
