嗨,我比较新的蓝牙模块。我最近买了一个DSPIC33 EP512控制器,现在我正在寻找一个蓝牙模块连接到我的MCU SUART,以沟通到我的手机。唯一的问题是我没有一个焊接套件。谁能指引我到一个需要零焊接的模块,它是一个简单的插头插入我的电路板?谢谢您。
以上来自于百度翻译 以下为原文 Hi, I relatively new to Bluetooth modules. I recently purchased a DSPIC33EP512 controller and now I am looking for a Bluetooth module to connect to my MCU's UART to communicate to my phone. The only issue is I do not own a soldering kit. Could anyone direct me towards a module that requires zero soldering and it is a simple plug into my breadboard? Thank you. |
8个回答
我过去只使用蓝色的WT11和类似的东西。我购买了模块本身,所以你需要一个焊料-不确定如果一些猪背或类似的板存在(也许检查SpkFun)。在任何情况下,你只需要电源引脚和RX/TX。
以上来自于百度翻译 以下为原文 I only used BlueGiga WT11 and alike in the past. I purchased the modules themselves so you needed a solder - not sure if some piggy-back or alike board exist (maybe check Sparkfun). In any case, you only need power pins and RX/TX |
嗨,你会发现一些预处理模块(点击板)的Mikroelektronika:HTTPS://Suff.MikRO.COM/点击他们已经连接了引脚,可能可以插入在面包店里注意。旧的点击板需要焊接…最近的一个是预处理的。在某个阶段,烙铁是强制性的;
以上来自于百度翻译 以下为原文 Hi, You will find some presoldered modules (click boards) by Mikroelektronika : https://shop.mikroe.com/click Some of them have already connected pins which can be probably inserted in a breadboard Pay attention. The older Click boards needed soldering...the recent ones come presoldered. At some stage a soldering iron will be mandatory ;=) Regards |
嗨,HC-05模块工作得很好,我用它们作为一个配对的主从遥感。同样,我使用HC05作为主人和HC06作为奴隶。HC05和HC06是蓝牙2 + EDR。有10米的范围。最近我在AyExcel中购买了10包AT-09,这些模块是HM10兼容的,并且是蓝牙4 BLE。这些模块有100米的范围。但我认为它将是HC05的一个很好的替代品。在AyExcel中链接到蓝牙模块:HTTPS://AISExpR.COM/ITEM/10PCS-LT-AT-09ANDROID-IOS-HM 10-BLU-BlueToT-4-0C-cc2540-cc2541-Serials/32686918228HTM。L?SPM= 211413010607.0.0.PFKHG6
以上来自于百度翻译 以下为原文 Hi, The HC-05 modules work very well, I use them as a paired master and slave for remote sensing. Too I use the HC05 as master and HC06 as slave. HC05 and HC06 are bluetooth 2.0 + EDR. And have 10 meters range. Recently I buy in Aliexpress a 10 pack of AT-09, these module are HM10 compatible, and are bluetooth 4.0 BLE. These module have 100 meters range. I still do not get it, but I think it's going to be a good replacement for the HC05. Best regards. Link to bluetooth module in Aliexpress: https://es.aliexpress.com/item/10pcs-lot-AT-09-Android-IOS-HM-10-BLE-Bluetooth-4-0-CC2540-CC2541-Serial-Wireless/32686918228.html?spm=2114.13010608.0.0.PFKhG6 |
你好,谢谢你的反馈。我在我的零件套件中找到了这个特殊的模块:DF BLUTITOTV3。我很确定我买了这一段时间的一个项目,但最终没有使用它。该模块是预焊接,这是很好的。下面是它的链接:http://www. dFooBOt.com / wiki / index。php/df BooLoToSv3BLooToToSuthMeule>(SKU:TEL00 26)我唯一关心的是它是否与我的DSPIC33 EP兼容。但我计划使用的是从RX端口接收信息,从我的手机发送,这不应该是一个问题。有什么想法吗?谢谢您!
以上来自于百度翻译 以下为原文 Hi, Thank you for the feedback. I found this particular module in my parts kit: DF-BluetoothV3. I'm pretty sure I purchased this awhile back for a project but ended up not using it. The module is pre-soldered which is nice. Here's the link to it: https://www.dfrobot.com/wiki/index.php/DF-BluetoothV3_Bluetooth_module_(SKU:TEL0026) My only concern is if its compatible with my dsPIC33EP. But all I plan on using is the module to receive information from the RX port, transmitted from my phone, which shouldn't be a problem. Any thoughts? Thank you! |
不仅没有拇指/星星对帖子进行评级,而且这个线程从不被标记为读。我认为有一些设置被这个FUMUM.EDIT弄糊涂了:最后它又被标记为“读取的、不可见的帖子”。
以上来自于百度翻译 以下为原文 Not only no thumbs/stars to rate posts but this thread never gets marked as read. I think there are some settings messed up with this forum. edit: finally it gets marked as read, invisible posts again |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-25 18:15 , Processed in 1.315797 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
