扫一扫,分享给好友
尝试在RHEL 5.5 x86_64和RHEL 6.4 x86_64上启动Vivado 2013.2 xsetup,并在两台计算机上启用itseg故障。
以下是RHEL 5.5框的输出: ./bin/lin64/xsetup:第21行:24393细分错误$ {XLNX_DIR_NAME} / _ xsetup“$ @” VIVADO闪屏显示约2-3秒后出现此错误,然后消失。 关于如何解决这个问题的任何指导都会很棒。 以上来自于谷歌翻译 以下为原文 Trying to launch Vivado 2013.2 xsetup on RHEL 5.5 x86_64 and RHEL 6.4 x86_64 and it seg faults on both machines. Here is the output from the RHEL 5.5 box: ./bin/lin64/xsetup: line 21: 24393 Segmentation fault ${XLNX_DIR_NAME}/_xsetup "$@" This error appears after the VIVADO splash screen displays for about 2-3 seconds then disappears. Any guidance on how to work around this would be great. |
3个回答
嗨,
你能尝试在批处理模式下安装vivado吗? 有关更多详细信息,请访问http://www.xilinx.com/support/answers/32330.htm 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Can you try installing vivado in batch mode? For more details refer to http://www.xilinx.com/support/answers/32330.htm Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
批量安装工作。
有没有办法在将来解决这个GUI问题? 以上来自于谷歌翻译 以下为原文 Batch install worked. Is there any way to get around this GUI problem in the future? |
嗨,很高兴听到它有效。在RHEL机器上的vivado 2013.2中看到这样的问题很少。是否可以附加机器的xinfo文件?谢谢,Deepika。
谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Good to hear that it worked. There have been few issues seen like this in vivado 2013.2 on RHEL machines. Is it possible to attach the xinfo file of the machine? Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
只有小组成员才能发言,加入小组>>
2159 浏览 7 评论
2601 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2072 浏览 9 评论
3141 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2187 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-18 04:05 , Processed in 1.225249 second(s), Total 75, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
