大家好。我使用PIC32 MX370F512H控制器,在EEPROM中有8KB的内存空间。目前在EEPROM中占用的内存大约是2KB,但是我的控制器的EEPROM内存没有被正确地分割。在考虑到将来的实现时,我需要适当地分割内存以避免数据冲突和数据丢失。EEPROM,是否有映射内存的标准?任何帮助都是有价值的。
以上来自于百度翻译 以下为原文 Hi all.. I am using PIC32MX370F512H controller. We have 8KB of memory space available in EEPROM. Currently memory occupied in EEPROM is around 2KB. But my Controller's EEPROM memory has not been segmented properly.Keeping in mind the future implementation I need to segment the memory properly to avoid data collision and data loss. What are the prerequisites to be considered for memory mapping my EEPROM. Is there any Standards for mapping memory. Any help would be valuable. |
4个回答
你在说什么EEPROM?没有内置到PIC32 MX370F512H。这是一个外部芯片吗?它是如何连接的?
以上来自于百度翻译 以下为原文 What EEPROM are you talking about? There is none built in to the PIC32MX370F512H. Is this an external chip? How is it connected? |
是的,QHB是正确的,什么是分段?碰撞,损失?如果你正在使用外部存储器,那么如果你用某些协议读写正确的地址,那么它将被内部控制。
以上来自于百度翻译 以下为原文 Yeah qhb is correct, And what segmentation? collision, loss? If you are using external memory then the it is all controlled internally if you are reading and writing to proper addresses with certain protocol. |
对。它是外部EEPROM。我们通过I2C进行读写,需要为不同的变量组和预留内存分段EEPROM存储器,通过编程控制。
以上来自于百度翻译 以下为原文 Yes. It is External EEPROM. We are reading/writing through I2C. I need to segment the EEPROM memory for different set of variable groups and reserved memory. We are controlling through Programming |
如何分配内存没有硬性规定。这完全取决于你。我真的不明白为什么你提到数据丢失和数据冲突,这完全是因为程序中的错误。
以上来自于百度翻译 以下为原文 There are no hard and fast rules on how to allocate the memory. It's all up to you. I don't really understand why you refer to data loss and data collision, that would solely be due to bugs in your program. |
只有小组成员才能发言,加入小组>>
4814 浏览 9 评论
1823 浏览 8 评论
1743 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2949 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2055 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1777浏览 0评论
GMT+8, 2024-4-20 01:11 , Processed in 1.413049 second(s), Total 70, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
