Heloi最近购买了新的PIC32 MK开发板,并为它配置了一个和声项目,包括FreeRTOS。当使用调试器(板上和皮卡3)在调用VTaskStistApple()之后应用程序崩溃时,问题是端口C中的变量UX中断嵌套是0 i。n的期望值为1(静态初始化为C)。现在我发现变量UXStutnEntIdStin刚好位于调试器RAM中的保留区域(位置0x800 0364)。当我在UxStuttNebug(在MAP文件中验证)之前插入一个测试变量时,测试变量被设置为0,UXStuttTestNestin值为1,这看起来像是启动代码或调试器/监视器中的一个错误,因为它溢出到用户RAM区域。我和新的PIC32 MK类似吗?我使用XC32 1.43和MPLAB X 3.61 +和谐2.03B.谢谢
以上来自于百度翻译 以下为原文 Hello I recently bought the new PIC32MK development board and configured a hARMony project for it, including FreeRTOS. When using the debugger(Onboard and PICKIT 3) the application was crashing after calling vTaskStartScheduler(), the problem was that the variable uxInterruptNesting in port.c was 0 instead of the expected value of 1(statically initialized in c). Now i found out that the variable uxInterruptNesting is located just after the reserved area in ram for the debugger (location 0x80000364). When i insert an test variable before uxInterruptNesting (verified in map file) the test variable is set to 0 and uxInterruptNesting is oke at the value 1. This kinda looks like an bug in the startup code or debugger / monitor to me, as it overflows to the user ram area. Did any one else encounter some thing similar with the new PIC32MK? I am using XC32 1.43 and MPLAB X 3.61 + harmony 2.03b. Thanks |
4个回答
你应该使用XC32 V1.42吗?和谐博士说什么?
以上来自于百度翻译 以下为原文 Are you supposed to be using xc32 v1.42? What does the Harmony docs say? |
不是XC32 V1.43版本有很多(新的)错误,因为狗可能有跳蚤?
以上来自于百度翻译 以下为原文 Isn't XC32 V1.43 the version with as many (new) bugs as a dog may have fleas ? |
您好,我也认为值得尝试XC32 V1.42,因为V1.43有一些问题。如果您的箱外和谐项目不运行如HORD手册中描述的那样,提交一个支持票到Microchip的支持,得到这个固定的问候。
以上来自于百度翻译 以下为原文 Hi, I also think it's worth trying XC32 v1.42 because v1.43 has some issues. If your Out of the box Harmony project does not operate as described in Harmony manual description, submit a support ticket to Microchip support to get this fixed Regards |
在V1.43中你指的是什么问题?我能想到的唯一一件事就是PINTF的64位INT问题。至于OP的原始问题,它不可能是链接器脚本问题吗?根据MK的默认链接器脚本,0x380字节应该为DeBug保留。
以上来自于百度翻译 以下为原文 What issues are you referring to with v1.43? The only thing I can think of off the top of my head is the 64bit int problem with printf. As to the OP's original problem, isn't it likely to be a linker script problem? According to the default linker script for the MK, 0x380 bytes should be reserved for the de-bugger. |
只有小组成员才能发言,加入小组>>
4823 浏览 9 评论
1828 浏览 8 评论
1747 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2951 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2059 浏览 5 评论
452浏览 1评论
1107浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
355浏览 0评论
260浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1786浏览 0评论
GMT+8, 2024-4-23 17:24 , Processed in 1.111984 second(s), Total 74, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
