我用cy7c64013 USB控制器和一个问题。我把endpoint2被中断了,endpoint4被中断。我使用Visual Basic生成WriteFile API调用触发endpoint2中断。这很好。然而,在endpoint2中断服务程序,我需要将数据发送回主机使用endpoint4。问:在endpoint2中断服务程序,是cy7c64013能够看到另一个中断endpoint4?我不能这样做。我相信cy7c64013中断系统被禁用,只要产生一个中断,虽然我不知道如果这是真的。我已经重新启用中断,一旦我进入endpoint2服务程序,但是我的代码是不能够看到endpoint4中断。有什么测试代码能告诉我怎么做吗?谢谢,George Frueh
以上来自于百度翻译 以下为原文 I am using the CY7C64013 USB controller and have a question. I have set Endpoint2 to be Interrupt OUT and Endpoint4 to be Interrupt IN. I am using visual basic to generate a writefile API call to trigger the Endpoint2 Interrupt. This works fine. However, while in the Endpoint2 interrupt service routine, I need to send data back to the host using Endpoint4. Question: While in the Endpoint2 interrupt service routine, is the CY7C64013 capable of seeing another interrupt on Endpoint4? I am not able to do this. I believe the CY7C64013 interrupt system is disabled as soon as an interrupt is generated, although I do not know if this is true. I have re-enabled interrupts a soon as I enter the Endpoint2 service routine, but my code is not able to see the Endpoint4 interrupt. Is there any test code that would show me how to do this? Thanks, George Frueh |
1个回答
在处理USB协议时,要记住的是数据包中的抽象…当EP2 ISR被触发时,意味着主机正在发送数据…没有办法主机可以在包的中间发送一个请求到EP4请求一个中断包…如果一个IN传输是由主机在外部传输之后触发的,那么EP4 ISR应该被触发…
以上来自于百度翻译 以下为原文 When dealing with USB protocol the abstraction to be in mind is in packets... when ep2 isr is triggered it means the host is sending in data... there is no way host can send a request in the middle of the packet to ep4 asking for a interrupt packet... if an in transfer is triggered by host right after the out transfer the ep4 isr should be triggered... |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
186浏览 2评论
183浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
321浏览 2评论
348浏览 1评论
62浏览 1评论
GMT+8, 2024-4-24 03:36 , Processed in 0.674893 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
