嗨,
我刚拿到带有spbtle-1的EVAL-IDB007V1M(基于bluenrg-1并在我的Windows PC上安装了STSW-BLUENRG1-DK(v2.5.0).BlueNRG-1 Navigator识别出EVAL-IDB007V1M,我可以' Flash& Run'基本示例和BLE演示和测试应用程序。 它们似乎在EVAL-IDB007V1M上运行 - 至少当我按下按钮时它们会出现问题,但我得到了奇怪的结果。 首先,当我'Flash&从我得到此输出的基本示例中运行'BlueNRG-1 Hello World: 使用另一个终端程序,它看起来像这样: 我期待Hello World ......怎么了? 第二个问题(在我的情况下更严重):当我闪存并运行BLE演示和测试应用程序时,我希望能够从我的Android智能手机建立与EVAL-IDB007V1M的连接。我尝试使用Apps STM32 BLE配置文件,BlueNRG和(对不起)nRF Connect。但我无法与EVAL-IDB007V1M建立任何联系。我试过几个演示应用程序,例如BLE Beacon。 我的智能手机上的应用程序和BLE内容工作正常,我可以连接到其他BLE设备。 再说一遍:怎么了? tiA 沃尔夫冈 #stsw-bluenrg1-dk#steval-idb007v1m #spbtle-1s #bluenrg-1 以上来自于谷歌翻译 以下为原文 Hi, I just got the EVAL-IDB007V1M with the spbtle-1s (based on bluenrg-1 and installed the STSW-BLUENRG1-DK (v2.5.0) on my Windows PC. The BlueNRG-1 Navigator recognizes the EVAL-IDB007V1M and I can 'Flash & Run' the basic examples and the BLE demonstration and test applications. They seem to run on the EVAL-IDB007V1M - at least they to something when I press the buttons but I get strange results. First, when I 'Flash & Run' the BlueNRG-1 Hello World from the basic examples I get this output: With another terminal program it looks like this: I expected Hello World... What's wrong? Second problem (and more severe in my case): When I flash and run the BLE demonstration and test applications I would expect to be able to establish a connection to the EVAL-IDB007V1M from my Android smartphone. I tried to use the Apps STM32 BLE Profiles, BlueNRG and (sorry for that) nRF Connect. But I couldn't get any connection to the EVAL-IDB007V1M. I tried several demo applications, e.g. BLE Beacon. The Apps and the BLE stuff on my smartphone works in general and I can connect to other BLE devices. Again: What's wrong? TIA Wolfgang #stsw-bluenrg1-dk #steval-idb007v1m #spbtle-1s #bluenrg-1 |
8个回答
嗨沃尔夫冈,
请注意,STSW-BLUENRG1-DK为您提供不同的应用程序。他们定义了不同的专有配置文件,并要求手机/平板电脑上的特定对应应用。 为了测试BLE功能,我建议在EVAL-IDB007V1M上运行BLE_SensorDemo应用程序。在这种情况下,您需要在Android手机上使用BlueNRG应用。 如果要构建和刷新BLE_SensorDemo项目,SW包中的相对路径为: 项目 BLE_Examples BLE_SensorDemo 如果您想使用预先构建的二进制文件,您可以在此处找到它: 固件 BLE_Examples BlueNRG-1 BLE_SensorDemo 终端程序的当前配置(115200,8N1,无流量控制)正常。 最好的祝福, 安东尼奥 以上来自于谷歌翻译 以下为原文 Hi Wolfgang, please keep into account that STSW-BLUENRG1-DK provides you with different applications. They define different proprietary profiles and require their specific counterpart app on the phone/tablet. In order to test the BLE functionality, I suggest to run the BLE_SensorDemo application on your EVAL-IDB007V1M. In this case, you will need to use the BlueNRG app on your Android phone. If you want to build and flash the BLE_SensorDemo project, the relative path within your SW package is: ProjectBLE_ExamplesBLE_SensorDemo If you want to use a pre-built binary, instead, you can find it here: FirmwareBLE_ExamplesBlueNRG-1BLE_SensorDemo Your current configuration for the terminal program (115200, 8N1, no flow control) is OK. Best regards, Antonio |
嗨Antonio,
谢谢你的快速回答。我已经使用过'Flash&运行'in'BlueNRG-1 Navigator'来刷新BLE_SensorDemo。 LED DL1闪烁了一点但我没有与我的智能手机(三星Galaxy S7)和来自不同供应商的三个不同应用程序的BLE连接:BlueNRG,nRF Connect和BLE Scanner。要确保我的智能手机上的BLE正常工作我使用了BLE HRM皮带,这三个应用程序都认可了它。 根据您的回答,我使用'BlueNRG-1 Flasher'实用程序再次刷新Firmware BLE_Examples BlueNRG-1 BLE_SensorDemo.hex文件。相同的行为:DL1闪烁但没有BLE连接到三个应用程序中的任何一个(BLE HRM皮带工作正常)... 这是闪烁BLE_SensorDemo.hex后的截图: 你有什么进一步的想法吗? 最好的祝福 沃尔夫冈 以上来自于谷歌翻译 以下为原文 Hi Antonio, thank you for your fast answer. I already used 'Flash & Run' in 'BlueNRG-1 Navigator' to flash the BLE_SensorDemo. The LED DL1 is flickering a little bit but I got no BLE Connection with my smartphone (Samsung Galaxy S7) and with three different apps from different suppliers: BlueNRG, nRF Connect and BLE Scanner.To make sure BLE on my smartphone works as it should I used a BLE HRM belt which was recognized by all three apps. With your answer I used the 'BlueNRG-1 Flasher' utility to flash the FirmwareBLE_ExamplesBlueNRG-1BLE_SensorDemo.hex file again. Same behaviour: DL1 is flickering but no BLE connection to any of the three apps (BLE HRM belt works fine)... This is a screenshot after flashing BLE_SensorDemo.hex: Do you have any further ideas what I could do? best regards Wolfgang |
亲
wreinig ,如果您使用的是EVAL-IDB007V1板,则必须更改SPBTLE-1S模块中使用的32 MHz晶振的设置。 BlueNRG-1导航仪预先配置为EVAL-IDB007V1板,其具有另一个晶体(16 MHz)。 请确保在项目设置中使用此设置: 您尝试的所有项目中的默认配置是16 MHz晶振(HS_SPEED_XTAL_16MHZ),这就是您无法使其与电路板配合使用的原因。 我自己没有任何EVAL-IDB007V1M板来测试它。如果这对你有用,请告诉我。 最好的祝福, 安东尼奥 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Dear wreinig ,if you're using the EVAL-IDB007V1 board, you have to change the setting for the 32 MHz crystal used in the SPBTLE-1S module. The BlueNRG-1 navigator is preconfigured for the EVAL-IDB007V1 board, which has another crystal (16 MHz). Please make sure that in your project settings you use this setting: The default configuration in all the projects that you have tried was for a 16 MHz crystal (HS_SPEED_XTAL_16MHZ) and that's why you were not able to make it work with your board. I don't have any EVAL-IDB007V1M board to test it myself. Please let me know if this works for you. Best regards, Antonio Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
完美 - 它的作品!
谢谢安东尼奥非常敬业的支持!因为我的Atollic TrueStudio 9.0.0工具链还没有工作,因为我预计Antonio会制作32MHZ版本的BLE_SensorDemo.hex,所以我可以测试我的评估板。很棒的支持! 也许ST应考虑更换BlueNRG-1 Navigator,以便识别STEVAL-IDB007V1M并闪烁32MHZ版本。这将有助于像我这样的新人。 现在我的下一个问题是使用Atollic TrueSTUDIO 9.0.0最好的问候构建一个工作的hex文件 沃尔夫冈 以上来自于谷歌翻译 以下为原文 Perfect - it works! Thank you Antonio for the very dedicated support! Because my Atollic TrueStudio 9.0.0 toolchain does not (yet) work as I expect Antonio made a 32MHZ version of BLE_SensorDemo.hex so I could test my evaluation board. Great Support! Maybe ST should think about changing the BlueNRG-1 Navigator so it could recognize the STEVAL-IDB007V1M and flashes a 32MHZ version. This would help newcomers like me. Now my next issue is to build a working hex file with the Atollic TrueSTUDIO 9.0.0 Best regards Wolfgang |
我正在使用IAR嵌入式工作台,我无法在任何地方找到这个符号(这在TrueSTUDIO中是微不足道的)。您是否有其他选择来定义它以及在什么范围内?
谢谢, 问候, 米蒂亚 以上来自于谷歌翻译 以下为原文 i am using IAR embedded workbench and i cannot find this symbol anywhere (it was trivial in TrueSTUDIO) . Do you have some alternatives where to define it and with what scope? Thank you, Regards, Mitja |
嗨Mitja,
你指的是什么符号?我担心我无法完全理解你的问题。 您能否提供有关您的请求的更多详细信息? 此外,如果这个新问题与原始主题无关,我建议开始一个新的主题,因为这将最大化从其他社区成员获得答案的机会。 最好的祝福, 安东尼奥 以上来自于谷歌翻译 以下为原文 Hi Mitja, what symbol are you referring to? I'm afraid I wasn't able to fully understand your question. Could you please add more details about your request? Also, if this new question is unrelated to the original topic, I would kindly suggest to start a new thread as this will maximize chances of getting an answer from other community members. Best regards, Antonio |
嗨Mitja,
在另一个帖子中读到你的另一条消息之后,我明白你指的是晶体的预处理器定义,即 。如果您使用的是IAR Embedded Workbench,请从菜单中选择'Project>选项...'然后您可以在C / C ++编译器部分的'预处理器'选项卡中定义它,如下图所示。 最好的祝福, 安东尼奥 以上来自于谷歌翻译 以下为原文 Hi Mitja, after reading another message of yours in another thread, I understood that you were referring to preprocessor define for the crystal, i.e. .If you're using IAR Embedded Workbench, from the menu select 'Project > Options...' and then you can define it in the 'Preprocessor' tab of the C/C++ Compiler section, as shown in the picture below. Best regards, Antonio |
感谢您的快速回复!它就像一个魅力!
问候, 米蒂亚 以上来自于谷歌翻译 以下为原文 Thank you for a fast response! It worked like a charm! Regards, Mitja |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1408 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
486浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
479浏览 3评论
GMT+8, 2024-4-19 14:47 , Processed in 0.998784 second(s), Total 80, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
