刚刚购买了87054A测试装置,用于我的8753C。
在3 GHz范围内一切都很好,但是当我转到6 GHz时,我得到一个“小心:可能的错误锁定”消息。 我已经完成了以下故障排除:1。当在3 GHz范围内设置2 GHz的CW频率时,我在连接到端口1或R输出(通过功率分配器)的specrum分析仪上获得了良好的单响应。 然而,进入6 GHz范围并设置任何CW频率(例如,2或4 GHz),我看到信号在整个地方跳舞。 它肯定没有锁定,似乎从DC-ish到3 GHz。 我没有看到3 GHz以上输出的迹象。 2. 8753C的射频输出电平似乎合理; 使用通过功率分配器插入RF OUT到RF IN路径的功率计我看到的信号在它们应该的位置的dB左右,我可以产生超过+20 dBm的输出。 3.我尝试在+10 dBm处施加2 GHz(尽可能多的曲柄)从单独的信号发生器到测试装置的RF IN端口,然后在两者中查看R输出(通过功率分配器) 3 GHz和6 GHz范围。 我认为这可能是赠品:在两个范围内,R端口的输出频率为2 GHz -12 dBm,但4 GHz输出低于-60 dBm。 因此,在切换频率范围时,输出信号没有区别,就好像没有使用倍频器一样。 我也做了一些其他的测试,但这三个似乎表明双倍的转换可能不起作用,永远不会被切换。 接收器期望信号的频率是它实际看到的频率的2倍,因此不满意并且不会锁定。 我现在最关心的是试图确定问题是否在测试集中,因为经销商给了我保修,我可能能够解决这个问题。 但我没有其他分析器或测试装置可以交换,因此我想尽可能多地做以避免发回未被破坏的东西。 (顺便说一句,我已经交换了射频和控制互连电缆,这没有任何区别。)我的诊断是否有意义? 我是否应该进行任何其他测试以最终确定进出其中一个方框? 谢谢,约翰 以上来自于谷歌翻译 以下为原文 Just acquired an 87054A test set to use with my 8753C. Everything is just fine in 3 GHz range, but when I go to 6 GHz, I get a "CAUtiON: POSSIBLE FALSE LOCK" message. I have done the following troubleshooting: 1. When setting a CW frequency of say 2 GHz in the 3 GHz range, I get a nice single response on a specrum analyzer connected to Port 1 or the R output (through a power divider). However, going to 6 GHz range and setting any CW frequency (e.g., either 2 or 4 GHz) I see the signal dancing all over the place. It's definitely not locked and seems to be sweeping from DC-ish through 3 GHz. I don't see any sign of output above 3 GHz. 2. RF output level from the 8753C seems to be reasonable; using a power meter inserted via power divider on the RF OUT to RF IN path I'm seeing signals that are within a dB or so of where they should be, and I can generate more than +20 dBm output. 3. I've tried applying 2 GHz at +10 dBm (as much as I can crank) from a separate signal generator to the RF IN port of the test set and then looking at the R output (through a power divider) in both 3 GHz and 6 GHz ranges. I think this may be the giveaway: in both ranges, the R port has a 2 GHz output at about -12 dBm but the 4 GHz output is lower than -60 dBm. So there's no difference in the output signal when switching frequency ranges, as if the doubler isn't being engaged. I've done some other tests as well but those three seem to indicate that the switch around the doubler probably isn't working and is never being switched in line. The receiver is expecting a signal at 2X the frequency it actually sees, and therefore is unhappy and doesn't lock. My biggest concern right now is trying to determine whether the problem is in the test set, since the dealer gave me a warranty and I may be able to make this *his* problem. But I don't have other analyzers or test sets to swap around, and therefore I want to do as much as I can to avoid sending back something that isn't broken. (By the way, I've swapped RF and control interconnect cables and that didn't make any difference.) Does my diagnostic make sense? Are there any other tests I should perform to definitively rule in or out one of the boxes? Thanks, John |
1个回答
我认为你的意思是85047A测试装置(据我所知,没有87054这样的东西)并且:你必须在8753C上有选项006。
如果是这样,当您将8753C设置为6 GHz模式时,测试装置上的灯会发生变化吗? 双倍开关是否点击进入? 当然,如果绕过倍频器,您将不会从测试装置中获得任何2x信号。 如果多年未使用测试装置,有时开关中的润滑脂会凝固并防止切换。 您可以通过打开盒子并测试其上的DC连接来检查开关。 中心引脚上应有24伏电压,外部两个电压驱动为开路集电极下拉。 因此,一个应该是大约0.4伏特而另一个应该是浮动的(它可能高达24伏特)。 当您将测试装置从3GHz模式切换到6 GHZ模式时,开关应该单击,外部引脚上的驱动器应该更改。 如果没有,则可能是控制板问题。 如果驱动器确实发生了变化,但交换机没有单击,则可能是卡住的开关。 在这种情况下,您可以从开关上取下盖子,用手移动执行器几次,它可能会修复它。 你可以自己测试倍增器。 它喜欢+20 dBm驱动器,但运行速度可达+13 dBm左右。 只需拉动倍频器,驱动输入并查看SA上的输出(或选择002的8753上的谐波测量模式......添加它以便更容易测试倍频器)。 倍频器应具有约-12 dBc的二次谐波,基波和其他谐波抑制约为20 dBc。 以上来自于谷歌翻译 以下为原文 I presume you mean the 85047A test set (no such thing as an 87054, as far as I know) AND: you have to have option 006 on the 8753C. If so, when you set the 8753C to 6 GHz mode, does the light change on the test set? And does the doubler switch click in? Of course, if the doubler is bypassed, you won't get any 2x signal out of the the test set. If the test set hasn't been used in years, sometimes the grease in the switch solidifies and keeps it from switching. You can check the switch by opening the box and testing the DC connection on it. There should be 24 volts on the center pin, and the outer two are driven as open collector pull downs. So one should be about 0.4 volts and the other should be floating (it might go as high as 24 volts). When you switch the test set from 3GHz mode to 6 GHZ mode, the switch should click, and the drives on the outer pins should change. If not, it might be a control board problem. If the drive does change, but the switch doesn't click, it might be a stuck switch. In such a case you can take the cover off the switch, move the actuator by hand a couple of times, and it might fix it. You can test the doubler by itself. It likes +20 dBm drive, but will operate down to about +13 dBm. Just pull the doubler, drive the input and look at the output on an SA (or on the 8753 with option 002, for harmonic measurement mode...it was added to make it easier to test the doubler). The doubler should have a second harmonic at about -12 dBc, with about 20 dBc fundamental and other harmonic suppression. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 02:08 , Processed in 1.115529 second(s), Total 70, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
