嗨,所有,我是新的PIC控制器。我使用的是D3200 07启动工具包,用于我的开发目的。现在,我遇到了一个严重的问题,无法发送来自董事会的电子邮件。我引用了在TCPIP文件夹中给出的几个项目,这些文件也失败了。我的参考项目是“WebSyServInVMMMPFS”,这也是我无法发送邮件的原因。我也在论坛上搜索过,这也没什么帮助。请帮我解决这个问题。我遇到了麻烦。我使用SMTP服务器作为“SMTP.Gmail”。
以上来自于百度翻译 以下为原文 Hi All, I am new to PIC controllers. I am using DM320007 starter kit for my development purpose. Now I'm in a serious trouble that can't send emails from that board. I refereed several projects given in the tcpip folder, which also fails. My reference project is "web_server_nvm_mpfs" from this also i couldn't send mails. I also searched in the forums, this also not helped. Please help me to solve this issue. I'm in a real trouble. I used smtp server as "smtp.gmail.com". |
13个回答
Gmail可能需要一些注册和认证-这已经在论坛上发表了一些时间…对不起,我不是一个大专家。
以上来自于百度翻译 以下为原文 Gmail may want some encription and authentication - this has been posted at the forum some times... Am sorry, I am not a big expert on that. |
我正在使用PIC演示代码。此外,我通过使用Gmail地址进行身份验证。
以上来自于百度翻译 以下为原文 I am using the PIC Demo code. Also I gave authentication by using gmail address. |
嗨,根据这个页面:HTTPS://www. DigalAudio./Cuulys/TutoRals/Houto GoGeLe-SMTP Server邮件需要身份验证(TLS/SSL),但TCP/IP不提供SMTP模块进行身份验证,因此您需要查找或设置另一个不需要认证的SMTP服务器。
以上来自于百度翻译 以下为原文 Hi, According to this page : https://www.digitalocean.com/community/tutorials/how-to-use-google-s-smtp-server GMAIL needs authentication (TLS/SSL) but Harmony TCP/IP does not offer SMTP module with authentication So you need to find or setup another SMTP server which does not need authentication Regards |
谢谢你的宝贵建议。你能给我推荐一些不需要认证的SMTP服务器吗?
以上来自于百度翻译 以下为原文 Thanks for your valuable suggestion. Can you please suggest me some SMTP servers, which doesn't need authentication. |
和谐可以提供狼SSL的TLS服务。必须协调一致。我是。它肯定它是默认的。或者你使用的是什么版本的和声。注狼SSL不是免费的商业用途。
以上来自于百度翻译 以下为原文 Harmony can offer wolf SSL for TLS service. It must be enabled in Harmony. I am. It sure what it is by default. Or what version of Harmony you are using. Note Wolf SSL is not free for commercial use. |
如果在因特网上留下任何开放和未加密的SMPT服务器,它们将成为垃圾邮件发送者的中继对象,这将是少之又少的。你需要为你做一些事情。您可以设置任何数量的SMTP服务器。
以上来自于百度翻译 以下为原文 There would be few if any open and unencrypted SMPT servers left on the internet, as they would become targets for spammers to relay off. You'll need to set up something to do the job for you.. There are any number of smtp servers that you coudl set up. |
你是如何连接到互联网的?几乎每个ISP都会提供自己可以使用的SMTP服务器。当然,您只能在连接到ISP时使用该SMTP服务器。正如已经提到的,从任何地方访问的开放式SMTP服务器都不存在,因为它们将被垃圾邮件发送者使用。
以上来自于百度翻译 以下为原文 How are you connected to the internet? Almost every ISP will provide their own SMTP server that you can use. Naturally, you can only use that SMTP server while you are connected to that ISP. As already mentioned, open SMTP servers that can be accessed from anywhere do not exist, because they would be used by spammers. |
我使用的是和声V2.02B。我还尝试了具有SSL的演示项目“WebSynNETServer NVMMMPFS”。但这也失败了。
以上来自于百度翻译 以下为原文 I'm using Harmony V2.02b. Also I tried the demo project "web_net_server_nvm_mpfs" having SSL. But that also failed. |
如果可以的话,你应该使用V2.03B。使用SSL,它应该与Gmail一起工作。我想你有一个被诬蔑的帐户和密码。
以上来自于百度翻译 以下为原文 You should be using v2.03b if you can. And with ssl it should work with gmail. I assume you have a vilified account and password. |
如果你的手机拼写检查是搞笑的尼尔,假设你的意思是“验证”:
以上来自于百度翻译 以下为原文 Some if your phone spell checks are hilarious Neil. Assume you meant "verified" :) |
您可能需要能够处理新版本的SSL(实际上是TLS现在)。旧的MLA中的SSL/TLS客户端现在已经过时。/ Ruben
以上来自于百度翻译 以下为原文 You probably need to be able to handle a newer version of SSL (actually TLS now). The SSL/TLS client in the old MLA is now obsolete. /Ruben |
Nivin,您确信您的SSL/TLS(SMTP之外)运行吗?您是否已经用PC进行测试以确保SMTP到您的邮件地址正确工作,希望SSL/TLS?如果无法使用StL/TLS操作SMTP,请使用WiReSrack查看连接故障何时发生。
以上来自于百度翻译 以下为原文 Nivin, Are you sure that your SSL/TLS operates (outside of SMTP) ? Have you made a test with a PC to ensure that SMTP to your mail address works correctly wish SSL/TLS ? If you cannot get SMTP to operate with SSL/TLS, use wireshark to see when the connection fails Regards |
如果你的电话拼写检查是搞笑的尼尔,假设你的意思是“核实”:你是正确的,先生。我想我应该先看一下再发。
以上来自于百度翻译 以下为原文 Some if your phone spell checks are hilarious Neil.Assume you meant "verified" :) You are correct sir. I guess I should read them before hitting send. |
只有小组成员才能发言,加入小组>>
4778 浏览 9 评论
1814 浏览 8 评论
1733 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2941 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2043 浏览 5 评论
418浏览 1评论
1100浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
343浏览 0评论
253浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1750浏览 0评论
GMT+8, 2024-3-28 19:03 , Processed in 1.194487 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
