默默的帮顶 同样不懂 我也在弄 不过我是不带系统的 我现在接受跟发送没有问题 但是 时间长了 就出错了 好像是阻塞了 一直也没时间找原因
不懂 默默的帮你顶起来!
LWIP 还没有接触到,先mark
是在运行时出错的。
PING是官方例程contrib-1.4.1: /** * @file * Ping sender module * */ /* * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * 2. Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation * and/or other materials provided with the distribution. * 3. The name of the author may not be used to endorse or promote products * derived from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY * OF SUCH DAMAGE. * * This file is part of the lwIP TCP/IP stack. * */ /** * This is an example of a "ping" sender (with raw API and socket API). * It can be used as a start point to maintain opened a network connection, or * like a network "watchdog" for your device. * */ #include "lwip/opt.h" #if LWIP_RAW /* don't build if not configured for use in lwipopts.h */ #include "ping.h" #include "lwip/mem.h" #include "lwip/raw.h" #include "lwip/icmp.h" #include "lwip/netif.h" #include "lwip/lwip_sys.h" #include "lwip/timers.h" #include "lwip/inet_chksum.h" #if PING_USE_SOCKETS #include "lwip/sockets.h" #include "lwip/inet.h" #endif /* PING_USE_SOCKETS */ /** * PING_DEBUG: Enable debugging for PING. */ #ifndef PING_DEBUG #define PING_DEBUG LWIP_DBG_ON #endif /** ping target - should be a "ip_addr_t" */ #ifndef PING_TARGET #define PING_TARGET (netif_default?netif_default->gw:ip_addr_any) #endif /** ping receive timeout - in milliseconds */ #ifndef PING_RCV_TIMEO #define PING_RCV_TIMEO 1000 #endif /** ping delay - in milliseconds */ #ifndef PING_DELAY #define PING_DELAY 20000 #endif /** ping identifier - must fit on a u16_t */ #ifndef PING_ID #define PING_ID 0xAFAF #endif /** ping additional data size to include in the packet */ #ifndef PING_DATA_SIZE #define PING_DATA_SIZE 32 #endif /** ping result action - no default action */ #ifndef PING_RESULT #define PING_RESULT(ping_ok) #endif /* ping variables */ static u16_t ping_seq_num; static u32_t ping_time; //OS_STK ping_thread_STK[512]; #if !PING_USE_SOCKETS static struct raw_pcb *ping_pcb; #endif /* PING_USE_SOCKETS */ /** Prepare a echo ICMP request */ static void ping_prepare_echo( struct icmp_echo_hdr *iecho, u16_t len) { size_t i; size_t data_len = len - sizeof(struct icmp_echo_hdr); ICMPH_TYPE_SET(iecho, ICMP_ECHO); ICMPH_CODE_SET(iecho, 0); iecho->chksum = 0; iecho->id = PING_ID; iecho->seqno = htons(++ping_seq_num); /* fill the additional data buffer with some data */ for(i = 0; i < data_len; i++) { ((char*)iecho)[sizeof(struct icmp_echo_hdr) + i] = (char)i; } iecho->chksum = inet_chksum(iecho, len); } #if PING_USE_SOCKETS /* Ping using the socket ip */ static err_t ping_send(int s, ip_addr_t *addr) { int err; struct icmp_echo_hdr *iecho; struct sockaddr_in to; size_t ping_size = sizeof(struct icmp_echo_hdr) + PING_DATA_SIZE; LWIP_ASSERT("ping_size is too big", ping_size <= 0xffff); iecho = (struct icmp_echo_hdr *)mem_malloc((mem_size_t)ping_size); if (!iecho) { return ERR_MEM; } ping_prepare_echo(iecho, (u16_t)ping_size); to.sin_len = sizeof(to); to.sin_family = AF_INET; inet_addr_from_ipaddr(&to.sin_addr, addr); err = lwip_sendto(s, iecho, ping_size, 0, (struct sockaddr*)&to, sizeof(to)); mem_free(iecho); return (err ? ERR_OK : ERR_VAL); } static void ping_recv(int s) { char buf[64]; int fromlen, len; struct sockaddr_in from; struct ip_hdr *iphdr; struct icmp_echo_hdr *iecho; while((len = lwip_recvfrom(s, buf, sizeof(buf), 0, (struct sockaddr*)&from, (socklen_t*)&fromlen)) > 0) { if (len >= (int)(sizeof(struct ip_hdr)+sizeof(struct icmp_echo_hdr))) { ip_addr_t fromaddr; inet_addr_to_ipaddr(&fromaddr, &from.sin_addr); LWIP_DEBUGF( PING_DEBUG, ("ping: recv ")); printf("ping: recv"); ip_addr_debug_print(PING_DEBUG, &fromaddr); LWIP_DEBUGF( PING_DEBUG, (" %"U32_F" msn", (sys_now() - ping_time))); iphdr = (struct ip_hdr *)buf; iecho = (struct icmp_echo_hdr *)(buf + (IPH_HL(iphdr) * 4)); if ((iecho->id == PING_ID) && (iecho->seqno == htons(ping_seq_num))) { /* do some ping result processing */ PING_RESULT((ICMPH_TYPE(iecho) == ICMP_ER)); return; } else { LWIP_DEBUGF( PING_DEBUG, ("ping: dropn")); } } } if (len == 0) { LWIP_DEBUGF( PING_DEBUG, ("ping: recv - %"U32_F" ms - timeoutn", (sys_now()-ping_time))); } /* do some ping result processing */ PING_RESULT(0); } static void ping_thread(void *arg) { int s; int timeout = PING_RCV_TIMEO; ip_addr_t ping_target; LWIP_UNUSED_ARG(arg); if ((s = lwip_socket(AF_INET, SOCK_RAW, IP_PROTO_ICMP)) < 0) { return; } lwip_setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof(timeout)); while (1) { //printf("ping...........rn"); ping_target = PING_TARGET; ping_target .addr=0XFE01A8C0;//192.168.1.254 if (ping_send(s, &ping_target) == ERR_OK) { LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); printf("ping: sendrn"); ip_addr_debug_print(PING_DEBUG, &ping_target); LWIP_DEBUGF( PING_DEBUG, ("n")); ping_time = sys_now(); ping_recv(s); } else { LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); ip_addr_debug_print(PING_DEBUG, &ping_target); LWIP_DEBUGF( PING_DEBUG, (" - errorn")); } sys_msleep(PING_DELAY); } } #else /* PING_USE_SOCKETS */ /* Ping using the raw ip */ static u8_t ping_recv(void *arg, struct raw_pcb *pcb, struct pbuf *p, ip_addr_t *addr) { struct icmp_echo_hdr *iecho; LWIP_UNUSED_ARG(arg); LWIP_UNUSED_ARG(pcb); LWIP_UNUSED_ARG(addr); LWIP_ASSERT("p != NULL", p != NULL); if ((p->tot_len >= (PBUF_IP_HLEN + sizeof(struct icmp_echo_hdr))) && pbuf_header( p, -PBUF_IP_HLEN) == 0) { iecho = (struct icmp_echo_hdr *)p->payload; if ((iecho->id == PING_ID) && (iecho->seqno == htons(ping_seq_num))) { LWIP_DEBUGF( PING_DEBUG, ("ping: recv ")); ip_addr_debug_print(PING_DEBUG, addr); LWIP_DEBUGF( PING_DEBUG, (" %"U32_F" msn", (sys_now()-ping_time))); /* do some ping result processing */ PING_RESULT(1); pbuf_free(p); return 1; /* eat the packet */ } } return 0; /* don't eat the packet */ } static void ping_send(struct raw_pcb *raw, ip_addr_t *addr) { struct pbuf *p; struct icmp_echo_hdr *iecho; size_t ping_size = sizeof(struct icmp_echo_hdr) + PING_DATA_SIZE; LWIP_DEBUGF( PING_DEBUG, ("ping: send ")); ip_addr_debug_print(PING_DEBUG, addr); LWIP_DEBUGF( PING_DEBUG, ("n")); LWIP_ASSERT("ping_size <= 0xffff", ping_size <= 0xffff); p = pbuf_alloc(PBUF_IP, (u16_t)ping_size, PBUF_RAM); if (!p) { return; } if ((p->len == p->tot_len) && (p->next == NULL)) { iecho = (struct icmp_echo_hdr *)p->payload; ping_prepare_echo(iecho, (u16_t)ping_size); raw_sendto(raw, p, addr); ping_time = sys_now(); } pbuf_free(p); } static void ping_timeout(void *arg) { struct raw_pcb *pcb = (struct raw_pcb*)arg; ip_addr_t ping_target = PING_TARGET; LWIP_ASSERT("ping_timeout: no pcb given!", pcb != NULL); ping_send(pcb, &ping_target); sys_timeout(PING_DELAY, ping_timeout, pcb); } static void ping_raw_init(void) { ping_pcb = raw_new(IP_PROTO_ICMP); LWIP_ASSERT("ping_pcb != NULL", ping_pcb != NULL); raw_recv(ping_pcb, ping_recv, NULL); raw_bind(ping_pcb, IP_ADDR_ANY); sys_timeout(PING_DELAY, ping_timeout, ping_pcb); } void ping_send_now() { ip_addr_t ping_target = PING_TARGET; LWIP_ASSERT("ping_pcb != NULL", ping_pcb != NULL); ping_send(ping_pcb, &ping_target); } #endif /* PING_USE_SOCKETS */ void ping_init(void) { #if PING_USE_SOCKETS //sys_thread_new("ping_thread", ping_thread, NULL, DEFAULT_THREAD_STACKSIZE, DEFAULT_THREAD_PRIO); sys_thread_new("ping_thread", ping_thread, NULL, DEFAULT_THREAD_STACKSIZE, 10); //OSTaskCreate(ping_thread,(void *)0,(OS_STK*)&ping_thread_STK[512-1],40); #else /* PING_USE_SOCKETS */ ping_raw_init(); #endif /* PING_USE_SOCKETS */ } #endif /* LWIP_RAW */ 发送PING后运行到api_lib.cr的函数netconn_recv()的 LWIP_ERROR("netconn_accept: invalid recvmbox", sys_mbox_valid(&conn->recvmbox), return ERR_CONN;)测试邮箱是否有效时出错: //检查一个消息邮箱是否有效 //*mbox:消息邮箱 //返回值:1,有效. // 0,无效 int sys_mbox_valid(sys_mbox_t *mbox) { sys_mbox_t m_box=*mbox; u8_t ucErr; int ret; OS_Q_DATA q_data; memset(&q_data,0,sizeof(OS_Q_DATA)); //mymemset(&q_data,0,sizeof(OS_Q_DATA)); //清除mbox的内存 ucErr=OSQQuery (m_box->pQ,&q_data);//查询消息队列 ret=(ucErr<2&&(q_data.OSNMsgs if (ret==0) { printf("邮箱无效.rn"); printf("消息邮箱的大小:%drn", q_data.OSNMsgs); printf("查询消息队列:%drn", ucErr); } //return 1; return ret; } 此时可看到q_data.OSQSize的值为0,正常应该是设定值500. 使用chargen例程时也出现了同样的问题。第一次进入chargen线程出现,然后在客户端连上后再断开时出现邮箱无效。 |
ucosIII+lwip是不是好点
直接不懂
我還是簽到就好,這裡真是厲害人物一對啊
跑操作系统。我还是默默去学习吧。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
579 浏览 1 评论
794 浏览 0 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
614 浏览 0 评论
自定义系统时钟频率后,用库函数和微带两种方式点亮LED灯,为什么灯的闪烁频率不一致?
1413 浏览 2 评论
1634 浏览 2 评论
GMT+8, 2024-4-19 19:41 , Processed in 0.569529 second(s), Total 72, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
