你好,
我想用matlab发送和接收数据通过USB到我的PSoC5。你们当中有人有经验可以帮助我吗?也许有一些例子代码? 我现在做的事情如下: -将CysUB-DLL添加到Matlab的程序集: 尝试 CysBDLL= NET .AdvAccess(C:CyPress)。……CYUSB·DLL’; 抓住E E.消息 如果(ISA,'NET.NETExpRebug) 例外对象 结束 其他的 DISP('CysB.DLL已加载); 返回; 结束 -获取USB设备列表 USB设备= CYUSB。USBDeviceList(CyUSB。Cycist.DeViSeSyCyUSB); 现在,我的问题是得到正确的设备实例。我的测试像 MyStudio= UBStudio.item('ItMeNeN'); 失败。它返回一个空变量(ANS=[])。 你们有人知道怎么得到这个吗? 亲切的问候, 费利克斯 以上来自于百度翻译 以下为原文 Hello, I would like to use MATLAB to send and receive Data via USB to my PSoC5. Has anyone of you some experiences to do this and can help me perhaps with some example-code? What I did until now is the following: - Add CyUSB.dll as an assembly to matlab: try CyUSBdll = NET.addAssembly('C:Cypress.. .. .. CyUSB.dll'); catch e e.message if(isa(e, 'NET.NetException') e.ExceptionObject end else disp('CyUSB.dll already loaded'); return; end - Get USB-Device list u***Devices = CyUSB.USBDeviceList(CyUSB.CyConst.DEVICES_CYUSB); Now, my problem is to get the right instance of the device. my tests like myDevice = u***Devices.Item('ITEMNAME'); failed. It returns an empty variable (ans = []). Has anyone of you an idea how to get this? Kind regards, Felix |
5个回答
请在PSoC论坛上发布这个问题。这将是获得这个问题的答案的最佳地点。
以上来自于百度翻译 以下为原文 Please post this question in the PSoC forums. That would be the best place to get your answers for this particular question. |
您好!
有人想出过这个吗?我很高兴我不是唯一试图在Matlab使用cyu***.dll,然而几个人贴出这样的问题,没有办法的。我研究了但我think.net图书馆CyUSB.dll不可用MATLAB。这个索引东西根本不起作用。 有人可以或许解释我如何能流数据从设备到PC?我的意图是 1。连接到设备(EZ-USB FX2) 2。请求数据 三。绘制数据 4。并将其保存到文本文件 MATLAB是最佳的选择,它可以做到4(我认为)却停留在1。 以上来自于百度翻译 以下为原文 Hi Has anyone figured this one out yet? I am glad I am not the only trying to use CyUSB.dll in Matlab, however several people posted this exact problem and no solutions. I have searched and searched but I think .NET library CyUSB.dll is not usable with Matlab. This indexing thing does not work out at all. Could someone perhaps explain how I can stream data from the device to PC? My intention is to 1. connect to device (EZ-USB FX2) 2. request data 3. plot data as it comes in 4. and save it to text file Matlab was the best choice as it could do all 4 (I thought) but stuck at 1. |
您好!
有人能帮我解决同样的问题吗? 你找到了一个合适的解决方案来将数据从设备流到PC机吗? 谢谢 以上来自于百度翻译 以下为原文 Hi can someone help me resolving the same problem locsong have you found a suitable solution to stream data from the device to pc ? thanks |
nige*** 发表于 2019-2-20 15:02 嗨,洛桑 你找到了一个合适的解决方案来将数据从设备流到PC机吗? 你能帮我吗? 谢谢 以上来自于百度翻译 以下为原文 Hi ,locsong have you found a suitable solution to stream data from the device to pc ? can you help me plz thanks |
你们真的想用USB把数据传输到Matlab或者仅仅是PC机吗?
以上来自于百度翻译 以下为原文 Do you guys really want to use USB to transfer data into MATLAB or just PC in general? |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1653 浏览 1 评论
3406 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
188浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
324浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-25 07:58 , Processed in 0.913515 second(s), Total 100, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
