嗨,杰里,
推荐用于新设计的SPWF01?您是否计划将来进行任何固件更新? 由于SPWF01不支持IPv6,但SPWF04不支持,我认为未来没有任何理由使用SPWF01。或者有没有理由使用SPWF01而不是SPWF04? Thx&问候, 流 以上来自于谷歌翻译 以下为原文 Hi Jerry, is the SPWF01 recommended for new designs? Do you have planned any firmware updates for future? Since the SPWF01 will not support IPv6, but the SPWF04 do, I don't see any reason to use the SPWF01 in the future. Or is there any reason to use the SPWF01 instead of the SPWF04? Thx & regards, Flow |
6个回答
嗨流,
SPWF01仍然推荐用于新设计。 SPWF04是新的,更强大,可能(预期!)更昂贵。 从每个角度看(自下而上),我们有:SPWF01Sx.21(没有额外闪光),SPWF01Sx.11(带额外闪光)和SPWF04Sx(顶级)。它们涵盖了不同的用例: - 如果你不需要OTA,永远不会使用01.11& 04 - 如果你不需要WPS,永远不会使用01.11和01.21 - 如果你想保留外部MCU,永远不会使用04 显然,使用SPWF04你拥有一切!但是,如果你不想支付一些从未使用过的东西,那么SPWF01仍然存在。并且,是的,路线图中的更新是为了满足云中的新需求。 无论如何,在我看来,WPS和WPA-Enterprise提供了很大的优势,而不仅仅是IPv6 ...... 再见 杰瑞 以上来自于谷歌翻译 以下为原文 Hi Flow, SPWF01 is still recommended for new designs. SPWF04 is new, is more powerful, and probably (expected!) is more expensive. From every point if view (bottom-up), we have: SPWF01Sx.21 (w/o extra flash), SPWF01Sx.11 (w/ extra flash), and SPWF04Sx (top level). They cover different use cases: - if you don't need OTA, will never use 01.11 & 04 - if you don't need WPS, will never use 01.11 and 01.21 - if you want to keep external MCU, will never use 04 Obviously, using SPWF04 you have everything! But, if you don't want to pay for something that will be never used, SPWF01 is still there. And, yes, an update is in roadmap to cover new needs from the cloud. Anyway, in my point of view, a big plus is provided by WPS and WPA-Enterprise, more than IPv6... Ciao jerry |
嗨,杰里,
非常感谢你的详细解答。 一些问题: - 如果你不需要OTA,永远不会使用01.11& 04 在SPWF04数据表中是OTA listentd的功能。 - 如果你想保留外部MCU,永远不会使用04 如果我有外置MCU,为什么我永远不会使用SPWF04? 谢谢。 干杯, 流 以上来自于谷歌翻译 以下为原文 Hi Jerry, thank you very much for your detailed answer. Some questions: - if you don't need OTA, will never use 01.11 & 04 In the SPWF04 data sheet is the feature OTA listetd. - if you want to keep external MCU, will never use 04 Why should I never use the SPWF04 if I have an external MCU? Thx. Cheers, Flow |
再见,
- OTA需要一个临时存储区域,由嵌入式(04)或扩展(01.11)设备提供。如果不需要,请使用01.21; - 04最大的优势是可以在没有外部MCU的情况下工作。无主机模式,由MicroPython引擎提供支持。 大多数客户不需要IPv6,OTA,WPS等。他们使用原始套接字开发更高级别的协议。在这种情况下,请使用01.21。 Ĵ 以上来自于谷歌翻译 以下为原文 Ciao, - OTA requires a temporary storage area, provided by embedded (04) or extended (01.11) devices. If not required, use 01.21; - 04 biggest advantage is the possibility to work without an external MCU. Host-less mode, powered by MicroPython engine. Most customers don't need IPv6, OTA, WPS, etc. They develop higher level protocols using raw sockets. In this case, use 01.21. j |
嗨,杰里,
感谢您的进一步解释。 BR, 流 以上来自于谷歌翻译 以下为原文 Hi Jerry, thanks for further explanations. BR, Flow |
嗨Gerardo,
我们有一个客户使用 SPWF04最近发现这个模块在待机模式下运行时会吸收大于1mA的电流而不是数据表中提到的uA电平。他们之前使用的是SPWF01,但没有看到这个问题。我是否知道SPWF04是否可以作为SPWF01的兼容替代品,硬件重新设计或AT评论设置的任何通知/提示?谢谢。 以上来自于谷歌翻译 以下为原文 Hi Gerardo, We have a customer using SPWF04 recently and found this module when running at standby mode would draw around >1mA current rather than uA level mentioned in the datasheet. They were using SPWF01 before and did not see this problem. May I know if SPWF04 could be a compatible replacement for SPWF01, any notice/tips for Hardware redesign or AT comment settings? Thanks. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1209 浏览 1 评论
1832 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1498 浏览 1 评论
2724 浏览 6 评论
4945 浏览 21 评论
293浏览 4评论
338浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
263浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
331浏览 3评论
345浏览 3评论
GMT+8, 2024-3-28 23:15 , Processed in 0.806522 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
