嗨,
我通过IPv4连接到SPWF01,并在我的路由器中连接端口。它工作正常,只要我有一个IPv4路由器/互联网连接。当我有IPv6连接和DS-Lite时,它不起作用。那么,是否有可能更新SPWF01 for IPv6? 最好的祝福, 弗洛里安 以上来自于谷歌翻译 以下为原文 Hi, I connect to the SPWF01 via IPv4 and a port forwarding in my router. It works fine, as long I have a IPv4 router / internet connection. When I have a IPv6 connection and DS-Lite it doesn't work. So, is there a possibility to update the SPWF01 for IPv6? Best regards, Florian |
6个回答
Ciao Flow,
IPv6不是SPWF01S功能的一部分。你可以切换到SPWF04S ...... 以上来自于谷歌翻译 以下为原文 Ciao Flow, IPv6 is not part of SPWF01S features. You can switch to SPWF04S... |
嗨格里,
谢谢您的回答。 不好,我无法切换,因为生产已经开始使用SPWF01S。在设计阶段,SPWF04不可用...... 那么,有没有计划在SPWF01中添加IPv6? 干杯, 流 以上来自于谷歌翻译 以下为原文 Hi Gerry, thank you for your answer. Poorly, I can't switch because the production already started with the SPWF01S. In the design phase, the SPWF04 wasn't available... So, there are no plans adding IPv6 to the SPWF01? Cheers, Flow |
我不这么认为。
Flash几乎已满,RAM有限,内部的LWIP版本不支持IPv4 + 6,SPWF04已经上市等等...... 以上来自于谷歌翻译 以下为原文 I don't think so. Flash is almost full, RAM is limited, LWIP version inside is not supporting IPv4+6, SPWF04 already on the market, etc... |
好的,那么我将看看如何更换SPWF01与SPWF04 ....
以上来自于谷歌翻译 以下为原文 Ok, then I will look how to replace the SPWF01 against the SPWF04.... |
从HW的角度来看,它们是引脚到引脚兼容的。此外,由于SPWF04S的GPIO高电平至3V3,因此不再需要TTL到MCU。
从AT命令的角度来看,它们是90%兼容的。 SPWF04S始终使用BNF来简化MCU管理(不再需要命令/数据模式): - AT + S.在命令上 - AT-S。同步事件 - 异步事件中的+ WIND:number:message [:param [:params ...]] BR Ĵ 以上来自于谷歌翻译 以下为原文 From HW point of view, they are pin to pin compatible. Moreover, since SPWF04S has GPIOs high level to 3V3, TTL to MCU is no more needed. From AT-commands point of view, they are 90% compatible. SPWF04S always uses a BNF to simplify MCU management (no more command/data mode): - AT+S. on commands - AT-S. on sync events - +WIND:number:message[:param[:params...]] on async events BR j |
嗨,杰里,
感谢您提供更多信息 - 听起来不错。 问候, 流 以上来自于谷歌翻译 以下为原文 Hi Jerry, thank you for the further information - sounds good. Regards, Flow |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1392 浏览 1 评论
2058 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1507 浏览 1 评论
2803 浏览 6 评论
5186 浏览 21 评论
351浏览 4评论
486浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
276浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
552浏览 3评论
466浏览 3评论
GMT+8, 2024-4-19 10:51 , Processed in 0.935285 second(s), Total 73, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
