您好,我们正在使用欧洲的MRF89XAM8A模块,该法规要求我们发射少于0.1%的时间。我们使用分组模式进行传输,并且它的工作效率高达15米。有没有办法将发射限制在模块侧的0.1%?谢谢你,莱欧
以上来自于百度翻译 以下为原文 Hello, We are using MRF89XAM8A module for Europe, and the legislation requires us to emit less than 0.1% of the time. We are using the packet mode for the transmission, and it works fine for up to 15 meters. Is there a way to limit emission to 0.1% of the time on the module side ? Thanks, Léo |
4个回答
由于占空比是在一个小时内测量的,所以我不这么认为,在模块和芯片手册中找不到任何东西。你必须在软件的更高层次上解决这个问题。确保你不经常发送超过0.1%的时间。下列限制:一小时内的总时间:一次传输的最大时间为3.6秒(0.1%):两次传输之间0.72秒的最小关断时间:0.72秒。/ Ruben
以上来自于百度翻译 以下为原文 Since the duty cycle is measured over a one hour period, I don't think so and could not find anything about that in the module and chip manual. You have to solve this at a higher level in your software. Make sure you don't send more often than 0.1% of the time. The following limitations apply: Total on time within one hour: 3.6 seconds (0.1%) Maximum on time for one transmission: 0.72 seconds Minimum off time between two transmissions: 0.72 seconds. /Ruben |
嗨,在这一页上你可以看到正在进行新的欧洲红色认证的RF模块列表。MICRF89XAM8A模块在列表中。在MRF89XAM8A页面上,HTTP://www. MigCHIP.COM/WWWORDSTMS/En/MRF89XAM8A点击文档标签,您将看到一份应用说明列表。我想你可以用AN1340(无线电驱动程序)来编程你的测试条件。
以上来自于百度翻译 以下为原文 Hi, On this page you can see the list of RF modules which are going through the new european RED certification. The MRF89XAM8A module is in the list. On the MRF89XAM8A page http://www.microchip.com/wwwproducts/en/MRF89XAM8A click on the documentation tab and you will see a list of application notes. I guess you can use the AN1340 (radio driver) to program your test conditions Regards |
感谢所有的回应,最后,唯一的方法是使用频谱分析仪测量发射时间。看起来16字节的数据包的发射大约为9Ms。换句话说,它允许每9秒发送一个16字节的数据包。
以上来自于百度翻译 以下为原文 Thanks for all your responses, At the end, the only way was to measure the emission time using a spectrum analyzer. It appears that the emission of a 16 bytes packet takes around 9ms. In other words, it is allowed to send a 16 bytes packets every 9 sec. Regards, Léo |
如果需要更多的话,868兆赫ISM波段的其他子带允许1%或10%占空比。/ Ruben
以上来自于百度翻译 以下为原文 There are other sub bands of the 868 MHz ISM band that allow 1% or 10% duty cycle if you need more. /Ruben |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1748 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2955 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2060 浏览 5 评论
461浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
263浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1799浏览 0评论
GMT+8, 2024-4-25 04:26 , Processed in 1.004092 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
