您好,我正在尝试使用A.09.90.06固件在PNA-X 43.5GHz的扫描IMD转换器(IMDX)通道上使用CalPods进行校准。但是,当我完成了cal并尝试'初始化通道
'使用Calpod菜单,它崩溃了网络分析仪应用程序。 当我将其重新加载并再次尝试时,我收到以下错误消息:'校准集不是由标准SParameter通道创建的。 无法执行此操作。 我的问题是这是一个有效的错误信息还是Calpods无法纠正扫描的IMDX测量通道。 如果答案是后者,那么CalPod初始化/重新校正将不起作用的是否还有其他测量类? 谢谢,rok 以上来自于谷歌翻译 以下为原文 Hello, I was trying to calibrate with CalPods on a swept IMD for Converters (IMDX) channel on a PNA-X 43.5GHz using A.09.90.06 firmware.. However, when I was done with the cal and tried to 'Initialize Channel' using the Calpod menu, it crashed the network analyzer application. When I loaded it back up and tried it again, I get this error message: 'The calset was not created by a standard SParameter channel. The operation cannot be performed.' My question is whether this is a valid error message or that Calpods cannot correct a swept IMDX measurement channel. If the answer is the latter, is there any other measurement classes that the CalPod intialization/recorrection won't work on? Thanks, rok |
10个回答
我们将分两个阶段进行攻击。
1.我们在9.90.07进行了一些CalPod更改,这可能会解决您的问题。 请先尝试安装该版本的固件,看看是否有帮助。 请在此回复您的调查结果。 http://na.tm.agilent.com/pna/firmware/firmware.html 2.如果这没有帮助,我们还有一个较新版本的CalPod软件正在进行一些测试。 如果#1不起作用,我们可能会让你尝试这个更新的软件....但是当我们到达那里时,让我们穿过那座桥。 以上来自于谷歌翻译 以下为原文 We are going to attack this in two stages. 1. We made some CalPod changes in 9.90.07 which may solve your issue. Please try to install that version of firmware first and see if that helps. Please report back here with your findings. http://na.tm.agilent.com/pna/firmware/firmware.html 2. If that does not help, we also have a newer version of the CalPod software that is undergoing some testing. If #1 does not work, we may have you try this newer software....but let's cross that bridge when we get there. |
嗨,安装了A.09.90.07固件并重复校准。 尝试在calpods上'初始化通道'时仍然得到相同的蓝色错误消息,尽管它似乎仍在后台执行某些操作(即在窗口1中出现和消失的迹线)。 我用A.09.90.06观察到了同样的行为。 如果您更新了beta calpod软件,我将很乐意尝试一下。 rokEdited by:rok on 2013年11月21日下午6:53 以上来自于谷歌翻译 以下为原文 Hi, Installed the A.09.90.07 firmware and repeated the calibration. Still got the same blue error message when trying to 'Initialize Channel' on the calpods, although it seem to still perform some operation in the background (i.e. traces appearing and disappearing in Window 1). So same behavior I've observed with the A.09.90.06. If you have updated beta calpod software, I'll be happy to try it out. rok Edited by: rok on Nov 21, 2013 6:53 PM |
蓝色冰汐 发表于 2019-2-13 08:55 我对提供此链接犹豫不决,因为我不确定这是否是正确的版本。 我会在早上发现。 链接是:http://69.12.214.222/calpod您可能想要尝试最新版本,但请记住,我仍然需要在早上与专家核实这一点。 我会转发(或者他会)。 以上来自于谷歌翻译 以下为原文 I am hesitant to provide this link because I am not sure if this is the correct version or not. I will find out in the morning. The link is: http://69.12.214.222/calpod You probably will want to try the latest version, but keep in mind I still need to verify this with the expert in the morning. I will repost (or he will) then. |
胡bbs2 发表于 2019-2-13 09:01 这是正确的链接,最新的链接目前是V1.9.5022.0,但请注意这些是beta版本,尽管1.9.5022.0可能会在下一个客户版本中升级。 此外,您应该在安装此版本之前手动卸载以前的版本(转到Windows控制面板,选择“添加或删除程序”并删除“Calpod API”)。 新版本采用安捷伦品牌,能够相互自动卸载,但无法自动卸载COMDEV与安捷伦合作开发的现有客户版本。 请告知我们您的问题的票价。 以上来自于谷歌翻译 以下为原文 That is the correct link and the latest one is currently the V1.9.5022.0, but be aware these are beta releases, although 1.9.5022.0 will potentially become promoted as the next customer release. Also, you should really manually uninstall the previous release before installing this one (go to Windows Control Panel, select "Add or Remove Programs" and remove "Calpod API"). The new releases are Agilent-branded and capable of auto-uninstalling each other, but they cannot auto-uninstall the existing customer releases which were developed by COMDEV in partnership with Agilent. Please let us know how this fares for your issue. |
uwyywefwd 发表于 2019-2-13 09:10 您好,终于开始测试beta calpod软件了。 单击“初始化通道”时,它不会再出现该错误。 但是,当我将初始化的calpod校准应用于测量文件中的类似通道并尝试“Recorrect Channel”时,它给了我另一个不同的错误消息。 ( 见附件)。 当我尝试运行测量时,它给了我一个垃圾波形。 请告知我接下来应该做什么。 韩国 以上来自于谷歌翻译 以下为原文 Hello, Finally gotten around to testing the beta calpod software. It doesn't have that error popping up anymore when 'Initialize Channel' is clicked. However, when I applied the initialized calpod calibration to a similar channel in a measurement file and tried 'Recorrect Channel', it gave me another different error message. ( see attached). When I tried running the measurement, it gave me a garbage waveform. Please advise what I should do next. rok 附件 |
蓝色冰汐 发表于 2019-2-13 09:15 您好,当您说您将初始化的calpod校准应用于“类似”通道时,我认为诊断此问题的关键可能是该通道与您初始化校准的通道之间的差异。 如果您可以请将仪器状态的'.csa'文件保存到您将初始化的CalSet应用到该文件的类似通道并发布该文件,这对诊断最有帮助,谢谢。 以上来自于谷歌翻译 以下为原文 Hello, when you say you were applying the initialized calpod calibration to a 'similar' channel, I believe the key to diagnosing this issue might be whatever is different between that channel and the one you initialized the cal on. If you could please perhaps save a '.csa' file of your instrument state with that similar channel where you'd applied the initialized CalSet to it and post that file, that would be most helpful in diagnosis, thank you. |
uwyywefwd 发表于 2019-2-13 09:28 嗨,附件是我用来使用calpods进行im3测量的csa文件。 需要帮助请叫我。 韩国 以上来自于谷歌翻译 以下为原文 Hi, Attached is the csa file I am using to make the im3 measurement using calpods. Let me know if you need anything else. rok 附件 |
您好,只是想知道是否在calpod扫描imdx问题上取得了任何进展。
我已经在两周前提交了状态文件,但是没有关于问题是否重复的状态。 只是想知道,rok 以上来自于谷歌翻译 以下为原文 Hello, Just wondering if there has been any progress made on the calpod swept imdx issue or not. I've submitted the state file over 2 weeks ago, but there have been no status posted on whether the problem was duplicated or not. Just wondering, rok |
蓝色冰汐 发表于 2019-2-13 09:53 您好,我很抱歉在论坛上发布回复延迟了:您的问题(我曾经出差)。 我们已经重现了这个问题,它与您在仪器状态下使用外部源作为LO的事实有关,而CalPod软件在尝试对该LO端口执行校正时遇到了问题。 我将与我们的产品规划人员讨论CalPod产品软件应该处理这种情况的正确方法,然后我们将回复您。 以上来自于谷歌翻译 以下为原文 Hello, my apologies for the delay in posting a response back here on the forum re: your issue (I had been on business travel). We have reproduced the problem, and it has to do with the fact you are using an external source as your LO in your instrument state, and the CalPod software is running into the issue when trying to perform correction for that LO port. I am going to discuss with our product planners for the CalPod product what is the right way that the software should handle this case, and then we will respond back to you. |
uwyywefwd 发表于 2019-2-13 10:02 在刚刚进行内部计划讨论之后,我认为我们知道对软件进行正确的更改以解决此问题。 我将研究我们能够在多长时间内实施和测试修复程序,并根据更改生成新的测试版,并且一旦我估计我们何时可以使用它,我将立即做出响应。 以上来自于谷歌翻译 以下为原文 After an internal planning discussion just now I think we know the right change to make to the software to resolve this. I will be looking into how soon we can implement and test the fix and produce a new beta release with the change, and will respond as soon as I have an estimate for when we expect we can have it available. |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
349浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
261浏览 0评论
2248浏览 0评论
1102浏览 0评论
GMT+8, 2024-3-29 09:01 , Processed in 1.119967 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
