移植了Communication.c 文件,但是就是不能成功驱动,写入寄存器和读取寄存器不一样,有没有移植成功过的发代码看看呢?
unsigned char SPI_Init_ad7124(unsigned char l***First, unsigned long clockFreq, unsigned char clockPol, unsigned char clockEdg) { CPU_SPI_Init(1, 8, SPI_Speed_Lowest, CPU_SPI_MODE_HD);//配置SPI口 CPU_IO_Init(IO_CPU_C, IO_Pin_8, IOMODE_OUT); //cs CPU_IO_WrBit(IO_CPU_C, IO_Pin_8, 0x00); return 1; /* Add your code here. */ } /***************************************************************************//** * @brief Reads data from SPI. * * @param slaveDeviceId - The ID of the selected slave device. * @param data - Data represents the write buffer as an input parameter and the * read buffer as an output parameter. * @param bytesNumber - Number of bytes to read. * * @return Number of read bytes. *******************************************************************************/ unsigned char SPI_Read(unsigned char slaveDeviceId, unsigned char* data, unsigned char bytesNumber) { CPU_IO_WrBit(IO_CPU_C, IO_Pin_8, 0x00); CPU_SPI_SendByte(1,data[0]); /* Add your code here. */ for(int i=1; i data = CPU_SPI_SendByte(1,data); } CPU_IO_WrBit(IO_CPU_C, IO_Pin_8, 0x01); return bytesNumber; } /***************************************************************************//** * @brief Writes data to SPI. * * @param slaveDeviceId - The ID of the selected slave device. * @param data - Data represents the write buffer. * @param bytesNumber - Number of bytes to write. * * @return Number of written bytes. *******************************************************************************/ unsigned char SPI_Write(unsigned char slaveDeviceId, unsigned char* data, unsigned char bytesNumber) { /* Add your code here. */ CPU_IO_WrBit(IO_CPU_C, IO_Pin_8, 0x00); CPU_SPI_SendByte(1, data[0]); for(int i=1; i CPU_SPI_SendByte(1, data); } CPU_IO_WrBit(IO_CPU_C, IO_Pin_8, 0x01); return bytesNumber; } |
13个回答
AD7124的SPI接口,需要sclk空闲状态为高电平,sclk上升对数据沿采样,这个是怎么设置的?
dsdfshf 发表于 2019-2-13 14:54 同求一份AD7124-4驱动,louxueqi@foxmail.com,感激ing |
dsdfshf 发表于 2019-2-13 14:54 大神能给我发一份驱动吗?我邮箱事915174852@qq.com |
dsdfshf 发表于 2019-2-13 14:54 同求一份AD7124-4驱动,263820640@qq.com,感激ing |
dsdfshf 发表于 2019-2-13 14:54 邮箱:duping2012@yeah.net,谢谢! |
是客户的,暂时还不便分享。 近期我们在跟朋友沟通,看还能在咱们ADI提供的驱动的基础上,完善下基于STM32标准外设库的驱动,然后公布出来。 |
赞!期待
只有小组成员才能发言,加入小组>>
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1290 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
3917 浏览 2 评论
8574 浏览 1 评论
2914 浏览 1 评论
6703 浏览 2 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
699浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1011浏览 2评论
3917浏览 2评论
938浏览 2评论
722浏览 1评论
GMT+8, 2024-4-20 05:08 , Processed in 0.557227 second(s), Total 62, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
