[C] 纯文本查看 复制代码
void tiM2_PWM_Init(u16 arr,u16 psc){GPIO_InitTypeDef GPIO_InitStructure;TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //TIM2_CH1GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIO//初始化TIM2TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_timTIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//初始化TIM2 Channel1 PWM模式TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高TIM_OC1Init(TIM2, &TIM_OCInitStructure); //根据T指定的参数初始化外设TIM3 OC2 TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable); //使能TIM2在CCR2上的预装载寄存器TIM_Cmd(TIM2,ENABLE);} |
3个回答
CCR1的值设置了么??
[C] 纯文本查看 复制代码
void TIM_PWM_Init(uint16_t arr, uint16_t psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOB, ENABLE); //开引脚复用AFIO时钟 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);//加上了这一句,禁用JTAG,我用的是JTAG下载 GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);//开TIM3部分重映射 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 |GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); TIM_TimeBaseStructure.TIM_Period = arr; TIM_TimeBaseStructure.TIM_Prescaler = psc; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC1Init(TIM3, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OC2Init(TIM3, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OC3Init(TIM3, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OC4Init(TIM3, &TIM_OCInitStructure); TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable); TIM_OC1Init(TIM4, &TIM_OCInitStructure); TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable); TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable); TIM_OC3Init(TIM4, &TIM_OCInitStructure); TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable); TIM_OC4Init(TIM4, &TIM_OCInitStructure); TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable); TIM_Cmd(TIM3, ENABLE); TIM_Cmd(TIM4, ENABLE); } int main(void) { delay_init(); LED_Init(); LED_Open(1); LCD_SPI2_Init(); NVIC_Configuration(); //中断分组 TIM_PWM_Init(19999, 71);//72000000/((19999+1)*(71+1))=50Hz while(1) { TIM_SetCompare1(TIM3,1300);//PB4 TIM_SetCompare2(TIM3,1700);//PB5 TIM_SetCompare3(TIM3,1300);//PB0 TIM_SetCompare4(TIM3,1700);//PB1 TIM_SetCompare1(TIM4,1300);//PB6 TIM_SetCompare2(TIM4,1700);//PB7 TIM_SetCompare3(TIM4,1300);//PB8 TIM_SetCompare4(TIM4,1700);//PB9 LCD_SPI2_P8x16Str(48,6,"OLED"); } } |
只有小组成员才能发言,加入小组>>
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
529 浏览 2 评论
551 浏览 2 评论
信号发生器产生的正弦频率信号,用定时器进行捕获,当幅值低于3V后为什么MCU就无法捕获到了?
209 浏览 2 评论
876 浏览 2 评论
编码器模式下,中断内访问其他定时器cnt值,会导致进入中断次数丢失的原因?
859 浏览 2 评论
1332浏览 9评论
STM32出现error downloading following files怎么解决?
29浏览 3评论
stm32f103的RST复位后PWM就停止输出了,为什么?
38浏览 3评论
STM32G0空闲中断异常,且DMA接收不到数据是怎么回事?
27浏览 3评论
STM32F103用Timer3TRGO通道触发ADC,ADC在三路输出PWM高电平中间点采样,如何配置?
17浏览 3评论
GMT+8, 2024-3-29 21:20 , Processed in 0.710135 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
