[size=0.875em]
- 1Applicable scope
- 1.1The operating system of evaluation board
- 1.2Operating system VS file system
- 2Prepare MFG Tool
- 3Configurate MFG Tool
- 3.1Configuration instructions
- 3.2Configuration instructions
- 4Configurate MFG Tool
- 4.1Unzip AndroidTool_Release_v2.35.rar
- 4.2Copy the downloaded Image to the appropriate directory
- 4.3Install driver
- 4.4Import the configuration
- 4.5Load image
- 5Configurate MFG Tool
- 6Bulk burning
Applicable scope
The operating system of evaluation boardEvaluation board | Supported Linux versions |
Linux-3.10.79 | NC | NC |
MY-RK3288-EK314 | √ |
Evaluation board | Android System version support |
Android-5.1.1 | NC | NC |
Operating system VS file systemBecause Linux OS correspond Multiple file system,the following table can support Correspondence:
In addition,the size of file system is very big,the minimal file system is only 6.9MB,big file system up to 1GB.In order to save everyone's download time, we first according to the table below the pre-selected file system, in the download file system that step can only download the file systemyou need.
Operating system | File system |
File system file name | File system file size | File system description |
linux-3.10.79 | linux-rootfs.img | 1.25GB | Ubuntu14.04 system file for MY-RK3288-EK314 |
Android-5.1.1 | system-ard511.img | 440MB | Android 5.1.1 File system |
Prepare MFG Tool
Contents of MFG Tool) In order to easy to understand MFG Tool ,below have a explanation about MFG Tool.
|-> AndroidTool_Release_v2.35
| |-> AndroidTool.exe: Main burn tool program
| |-> config.cfg: android configuration
| |-> rk32-myzr-ubuntu.cfg: Ubuntu configuration
|-> DriverAssitant_v4.2
| |-> DriverInstall.exe: RK3288 USB Chip drive, burn write needs
|-> rockdev
| |-> Image
| |-> linux
| |-> RK3288UbootLoader_V2.30.10.bin: u-boot file
| |-> rk3288box-3.10-uboot-ubuntu.parameter.txt:Environment Variables
| |-> linux-boot_lvds.img:lvds Image file
| |-> linux-boot_hdmi.img:hdmi Image file
| |-> linux-boot_edp.img: edp Image file
| |-> linux-rootfs.img:file system
| |-> android
| |-> RK3288UbootLoader_V2.30.10.bin:u-boot file
| |-> rk3288box-3.10-uboot-android.parameter.txt:environment Variables
| |-> resource-lvds.img:lvds device tree file
| |-> resource-hdmi.img:hdmi device tree file
| |-> resource-edp.img: edp device tree file
| |-> boot.img:Android's initial file image, which initializes and loads the system partition
| |-> kernel.img:kernel file
| |-> misc.img:misc Partitioned image, responsible for parameter transfer in startup mode switching and rescue mode
| |-> recovery.img:First aid mode image
| |-> system.img:Android system partition image
| |-> relase_update.img: ubuntu14.04 mirror image
| |-> relase_android_update.img: android5.1 mirror image
Configuration instructions File name:AndroidTool_Release_v2.35.rar
Configuration instructions Precompiled folder: Image
Unzip AndroidTool_Release_v2.35.rarCopy the downloaded Image to the appropriate directoryInstall driverDouble-click DriverInstall.exe to start the installation.
Import the configuration1)Import Android configuration
Double-click “AndroidTool.exe”
After opening“AndroidTool.exe”,right-click "import configuration" and find the directory AndroidTool_Release_v2.35config.cfg file.
2)Import ubuntu configuration
After opening“AndroidTool.exe”,right-click "import configuration" and find the directory AndroidTool_Release_v2.35rk32-myzr-ubuntu.cfg file
Load imageClicking on the far right of the "tick" option corresponds to selecting the corresponding file of the absolute path "rockdev Imageandroid" or "rockdev Image Linux"
Android image:
ubuntu image:
The board is connected to the 5V power supply, turn on the power switch, directly press the “RECOVERY” button, then press the “SW3” button, and see that the power indicator light is on, first release the “SW3” button, then release the “RECOVERY” button, the software "AndroidTool.exe" will display "Discover a LOADER device"
Click "execute" to start writing, and when the writing is finished, the system will be restarted automatically (usually 100%).
Bulk burning
You can package the relevant image of android or ubuntu into relase_android_update.img or release_update.img
Click "firmware" to find relase_android_update.img or release_update.img absolute path
Click "Upgrade" to start programming (before burning, see "Discover a LOADER device")
